[Mapserver-users] Compiling MapServer - a few problems
"Ryszard Bratu"
rb at bmtcordah.pl
Thu Jun 26 08:33:11 EDT 2003
Just for a few days I discover a power of MapServer so I'm still newbe.
I try to compile myself mapserver 3.6.6 on Windows2000 Prof.
Sources come from http://mapserver.gis.umn.edu/dload.html
All went OK (after changing makefiles and so on..) when I compiled mapserver with
supporting packages (gd, libJPEG, zlib, regex).
But.. :
I want to use in MapServer some formats supported in GDAL/OGR.
The first problem is that linker complains when try to link mapserver with gd.lib and gdal.lib
(the same functions in both libraries). It's normal I think , I decided to exclude
(ie. PNG support from one of libraries).
I have a look into sources and found that pnglib version is GDAL is much older
than correspoding sources in GD-1.8.4. (more than a year).
So I wonder if is it worth to compile GDAL without PNG support.
Which parameters (in GD and GDAL) are responsible for incl. or excluding chosen formats ?
What will be, if I compile supporting libraries to Dll's ? Could it be problem for mapserver ?
Ryszard Bratus
BMT Cordah
Poland
