[Mapserver-users] Generate a shp
Bjoern Platzen
bplatzen at sosnetz.de
Fri Jun 27 02:17:08 EDT 2003
Hi!
If you have a program like ESRI ArcView, you could import your textfile
as a table into a project and create an event layer out of it. This
eventlayer can be saved as a shapefile.
hth,
Bjoern.
Am Freitag, 27. Juni 2003 07:21 schrieb Chen Fu:
> Hi!
> This problem has not directly relation to mapserver,
> but i think somebody in the list know how to do it.
> I scan a history map, and position some cities
> thousands years before. And my program produce a text
> file with infomation of latitude, longitude and city's
> name.
> for example
> 50, 110, apple
> 40, 120, banana
> How can i make this info into a shp file?
> This is only point data up to now. But the next step
> of my work will also trace the old kingdom's territory
> that will produce some polyline data.
> Is there any good tool to generate shp file? Can you
> give me some suggestion?
> Remote Scensing Satellite Ground Station
> Chinese Academy of Science
> _________________________________________________________
> Do You Yahoo!?
> ÍøÁµµÄÚ¹ÊÍ£ºÕæÇ黹ÊÇ·Å×Ý£¿
> http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/netlo
>ve _______________________________________________
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
small office solutions
info at sosnetz.de - http://www.sosnetz.de
