[Mapserver-users] shared libraries error
Daniel Morissette
morissette at dmsolutions.ca
Fri Jun 27 09:56:13 EDT 2003
RedHat 9 and 7.3 use different versions of various shared libraries.
You should look for a RH 7.3 system to compile on... that may not work
right away, but you'll have more chances of success.
Daniel
> Eduardo Patto Kanegae wrote:
> I've compiled MapServer ( version 3.6.6 OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=TTF INPUT=EPPL7 INPUT=SHAPEFILE ) on a Red Hat 9
> Linux server, tested it with Itasca and that's ok.
> However, after uploading its binaries to my internet linux web server
> ( which is a Red Hat 7.3 and I do not have compilation permissions), I
> tried to test it using a command:
> $ ./mapserv -v
> but I only got this error:
> ./mapserv: error while loading shared libraries: libstdc++.so.5:
> cannot open shared object file: No such file or directory
> What is wrong
> thanks
> eduardo at linkgeo.com.br
