[Mapserver-users] php_mapscript.so loading problem
Vincent Schut
schut at sarvision.com
Mon Jun 30 06:21:32 EDT 2003
Rudolfo,
(please reply also to the list 'cause others might either learn from our
discussion or have more knowledge than I have :))
It appears that your php_mapscript.so links to a libgd that it (or the dynamic
linker) cannot find.
What does 'ldd php_mapscript.so' give you as output? Probably a libgd that
cannot be found...
Is the installation path of your libgd (probably /usr/local/lib) in your
LD_LIBRARY_PATH environment variable, or in your /etc/ld.so.conf? It should
be, otherwise the dynamic linker will not be able to find it if mapserver
requires it.
If it is, did you run 'ldconfig' (as root) after installing libgd?
Cheers,
Vincent.
On Thursday 26 June 2003 18:36, Rodolfo Federico Gamarra wrote:
> Thanks, good idea. I'll take a look at the error:
> 7:Jun 26 10:17:07 myEWS php: PHP Warning: Unknown(): Unable to load
> dynamic library '/usr
> /local/apache2/modules/php_mapscript.so' - libgd.so.2: cannot open shared
> object file: No such file or directory in Unknown on line 0
> Thanks again for your quick response,
> On Thu, 26 Jun 2003, Vincent Schut wrote:
> > Date: Thu, 26 Jun 2003 17:13:53 +0200
> > From: Vincent Schut <schut at sarvision.com>
> > To: Rodolfo Federico Gamarra <rgamarra at dc.uba.ar>,
> mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] php_mapscript.so loading problem
> > If php tried to load php_mapscript.so but did not succeed, probably there
> > is a message aboug that in your server log which might give you a hint
> > about why.
> > Cheers,
> > Vincent.
> > On Thursday 26 June 2003 16:26, Rodolfo Federico Gamarra wrote:
> > > Hi,
> > > I've trying to install php_mapscript. I've followed the standard
> > > procedure of making the file and then copying it to the directory where
> > > php looks for extensions (set in php.ini).
> > > Then to see if everything went right I made a ".php" where I load (or,
> > > at least, try to :-)) the ".so" with dl and se call phpinfo(). In the
> > > info shown by phpinfo there's no sign of mapscript. Then to make more
> > > checks I added an if to capture de return value of dl and also used
> > > extension_loaded after dl to see if it's loaded. Well, the result of
> > > both functions says it isn't loaded the ".so". I also loaded the file
> > > "/mapscript/php3/example/test_draw_map.phtml", all I see is a grey page
> > > with the title "PHP/MapScrpt module test", without a map.
> > > I'm running RedHat 8, with:
> > > Apache - httpd-2.0.45
> > > Mapserver - mapserver-3.6.5
> > > Php - php-4.3.1
> > > GD - gd-2.0.12
> > > Well, that's the problem; any idea?
> > > Thanks,
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Vincent Schut
> > Sarvision B.V.
> > Wageningen, The Netherlands
> > www.sarvision.com
Vincent Schut
Sarvision B.V.
www.sarvision.com
