[Mapserver-users] php_mapscript.so loading problem
Vincent Schut
schut at sarvision.com
Thu Jun 26 11:13:53 EDT 2003
If php tried to load php_mapscript.so but did not succeed, probably there is a
message aboug that in your server log which might give you a hint about why.
Cheers,
Vincent.
On Thursday 26 June 2003 16:26, Rodolfo Federico Gamarra wrote:
> Hi,
> I've trying to install php_mapscript. I've followed the standard procedure
> of making the file and then copying it to the directory where php looks
> for extensions (set in php.ini).
> Then to see if everything went right I made a ".php" where I load (or, at
> least, try to :-)) the ".so" with dl and se call phpinfo(). In the info
> shown by phpinfo there's no sign of mapscript. Then to make more checks I
> added an if to capture de return value of dl and also used
> extension_loaded after dl to see if it's loaded. Well, the result of both
> functions says it isn't loaded the ".so". I also loaded the file
> "/mapscript/php3/example/test_draw_map.phtml", all I see is a grey page
> with the title "PHP/MapScrpt module test", without a map.
> I'm running RedHat 8, with:
> Apache - httpd-2.0.45
> Mapserver - mapserver-3.6.5
> Php - php-4.3.1
> GD - gd-2.0.12
> Well, that's the problem; any idea?
> Thanks,
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
