[Mapserver-users] Retriving class of a result
Lowell.Filak
lfilak at medinaco.org
Mon Jun 30 13:02:46 EDT 2003
Try setting $c at the same time your setting $id just as a check to see if
somehow one of the other methods is changing the value of what $rslt
points to.
Also you may want to include the code segment where $rslt is set.
Of course you probably already have this solved with the post being a week
old now.
Lowell
On 20 Jun 2003 giorgio at ufo.nauta.it wrote:
> I can't find a way to retrieve the class of a shape found with a query ....
> my $id=$rslt->{shapeindex};
> my $shp = new shapeObj($mapscript::MS_SHAPE_POLYGON);
> $layer->open($me->mappa->{shapepath});
> $layer->getShape($shp,$rslt->{tileindex},$id);
> my $c= $rslt->{classindex};
> my $class= $layer->getClass($c);
> but $c is always an empty string!
> Tried also $c= $shp->{classindex}; but $c is always 0!!!
> Can anybody suggest a solution?
> (using mapserver 3.5 and perl mapscript ....)
> thankyou!
> Giorgio
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
