[Mapserver-users] Mapserver crashes if I load a png
Carsten Busch
carsten.busch at uni-jena.de
Fri Jun 20 11:50:32 EDT 2003
When I try to show a png file via mapserv I get an Internal Server Error.
The apache log contains:
Premature end of script headers: /usr/local/apache/cgi-bin/mapserv
The error occurs only, if parts of the png should be visible, if I get a
different part wich does not contain oder intersects the png, then I get
no errors.
I suppose my png support is wrong, does anybody has an idea?
I use mapserver with postgis and the follow configuration/libraries:
mapserver-3.6.6, postgresql-7.3.3/,postgis-0.7.5/,php-4.3.2/
[root at jena cgi-bin]# ldd mapserv
libgd.so.2 => /usr/lib/libgd.so.2 (0x40025000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x4005c000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x4007d000)
libpng.so.3 => /usr/lib/libpng.so.3 (0x400cc000)
libz.so.1 => /lib/libz.so.1 (0x400f1000)
libpdf.so.1 => /usr/local/lib/libpdf.so.1 (0x400ff000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x40193000)
libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x401c7000)
libpq.so.3 => /usr/lib/libpq.so.3 (0x4043c000)
libwwwxml.so.0 => /usr/lib/libwwwxml.so.0 (0x40452000)
libxmltok.so.0 => /usr/lib/libxmltok.so.0 (0x4045e000)
libxmlparse.so.0 => /usr/lib/libxmlparse.so.0 (0x40478000)
libwwwzip.so.0 => /usr/lib/libwwwzip.so.0 (0x40481000)
libwwwinit.so.0 => /usr/lib/libwwwinit.so.0 (0x40484000)
libwwwapp.so.0 => /usr/lib/libwwwapp.so.0 (0x40487000)
libwwwhtml.so.0 => /usr/lib/libwwwhtml.so.0 (0x4049f000)
libwwwtelnet.so.0 => /usr/lib/libwwwtelnet.so.0 (0x404ac000)
libwwwnews.so.0 => /usr/lib/libwwwnews.so.0 (0x404af000)
libwwwhttp.so.0 => /usr/lib/libwwwhttp.so.0 (0x404b8000)
libwwwmime.so.0 => /usr/lib/libwwwmime.so.0 (0x404cc000)
libwwwgopher.so.0 => /usr/lib/libwwwgopher.so.0 (0x404d6000)
libwwwftp.so.0 => /usr/lib/libwwwftp.so.0 (0x404dc000)
libwwwfile.so.0 => /usr/lib/libwwwfile.so.0 (0x404e5000)
libwwwdir.so.0 => /usr/lib/libwwwdir.so.0 (0x404ef000)
libwwwcache.so.0 => /usr/lib/libwwwcache.so.0 (0x404f5000)
libwwwstream.so.0 => /usr/lib/libwwwstream.so.0 (0x404ff000)
libwwwmux.so.0 => /usr/lib/libwwwmux.so.0 (0x40506000)
libwwwtrans.so.0 => /usr/lib/libwwwtrans.so.0 (0x4050b000)
libwwwcore.so.0 => /usr/lib/libwwwcore.so.0 (0x40511000)
libwwwutils.so.0 => /usr/lib/libwwwutils.so.0 (0x4053a000)
libmd5.so.0 => /usr/lib/libmd5.so.0 (0x40542000)
libdl.so.2 => /lib/libdl.so.2 (0x40545000)
libssl.so.0.9.7 => /usr/lib/libssl.so.0.9.7 (0x40548000)
libcrypto.so.0.9.7 => /usr/lib/libcrypto.so.0.9.7 (0x40577000)
libm.so.6 => /lib/i686/libm.so.6 (0x40665000)
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40687000)
libc.so.6 => /lib/i686/libc.so.6 (0x40739000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4086c000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x40875000)
libresolv.so.2 => /lib/libresolv.so.2 (0x408a3000)
libnsl.so.1 => /lib/libnsl.so.1 (0x408b4000)
libssl.so.0 => /usr/lib/libssl.so.0 (0x408c8000)
libcrypto.so.0 => /usr/lib/libcrypto.so.0 (0x408f7000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
Viele Grüsse von
Carsten Busch
* Geographisches Institut FSU Jena *
* email: ncb at uni-jena.de *
* Tel:+49-3641-9-48866 Fax:+49-3641-9-48852 *
* mobil:+49-177-8950892 *
