[Mapserver-users] Error when using labels TYPE=truetype
Björn Platzen
bplatzen at sosnetz.de
Fri May 2 11:32:24 EDT 2003
Hi Thorsten,
> This can happen for several reasons. The most common one for me is
> that your GD library was not linked against the same version of
> FreeType as your mapserver binary. Since your are using SuSE, it's
> quite likely that you have more than one version installed. Use the
> 'ldd' command to find out about the libraries your programs are
> linked against.
Thanks! I compiled with a patched gd-2.0.7 while on my system there was
I think gd-1.8.x without GIF-support...
I'll check this ... and hope that I get it working ...
> chmod 755 is a bit too much btw, that makes your font files
> executable
> :) 644 should do fine.
755 was the "last try"...
Thanks & bye,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
