AW: [Mapserver-users] displaying lat/long maps
Christina Biakowski CCGIS
christina.biakowski at ccgis.de
Tue May 6 05:28:31 EDT 2003
Ellen,
in my Mapfile (for WGS84) it works with defining
PROJECTION
"init=EPSG:4326"
END
in the Map- and in the Layer-Section.
If your map is not composed of Layers with different Spatial Reference
Systems (no on-the-fly-projection) you even can omit the Projection-tag. But
if e.g. your Layer "Brandenburg" was in Gauss-Krüger 4 and you wanted to
display it in WGS84, then in the Map-Section you would have to declare
.."init=EPSG:4326".. and in the Layer-Section "init=EPSG:31494".
I hope this helps!
Best regards,
Christina
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von
Brachmann, Ellen
Gesendet: Dienstag, 6. Mai 2003 10:29
An: 'mapserver-users at lists.gis.umn.edu'
Betreff: [Mapserver-users] displaying lat/long maps
Hi all,
I've got a problem displaying lat/long maps.
I tested a lot, but no result (filled map or exception).
The specific part of the MAP file is:
NAME BRANDENBURG
STATUS ON
SIZE 200 200
SYMBOLSET "symbols/line.sym"
FONTSET "fonts/fonts.txt"
EXTENT 11.25 51.30 14.80 53.60
UNITS dd
SHAPEPATH "geo"
TRANSPARENT ON
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
WEB
TEMPLATE map.html
MINSCALE 1
MAXSCALE 150000000
IMAGEPATH "...
IMAGEURL "...
METADATA
"wms_title" "...
"wms_abstract" "...
"wms_onlineresource"
"http://10.133.4.212:81/cgi-bin/mapserv?map=wms/GEOdnm100.map"
"wms_srs" "EPSG:4326"
"wms_fees" "...
"wms_keywordlist" "...
END
END
LAYER
METADATA
"wms_title" "Brandenburg"
END
NAME state
MINSCALE 1
MAXSCALE 150000000
TYPE POLYGON
DATA geo_dnmvg_kreis
STATUS default
CLASSITEM 'LANDKREIS'
CLASS
NAME "Brandenburg"
EXPRESSION /./
COLOR 255 255 224
OUTLINECOLOR 0 0 0
END
PROJECTION
"proj=latlong"
END
END
What Did I wrong ?
The mapserver-parameters are:
MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7
INPUT=JPEG INPUT=SHAPEFILE
Regards
Ellen
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
