AW: [Mapserver-users] displaying lat/long maps
Brachmann, Ellen
Ellen.Brachmann at LVERMAP.brandenburg.de
Tue May 6 08:01:45 EDT 2003
Christina,
thanks for your help.
After changing the PROJECTION parameter, we got problems with the Projection
(famous error no. 2).
So we use the system-wrapper wms110 (with PROJ_LIB=YES) to call the
mapserver. He demands the files
proj_def.dat, EPSG (lib_proj itself) and epsg (mapserver), see error_log.
After clearing this problems the result file is empty too (see access_log,
result 200).
If we delete the PROJECTION entries completly the result is the same.
A shell-wrapper with different arguments tells us, that the mapserv
terminates correctly.
The mapserv-version 3.6.1 and 3.6.5 tells the same result, so it seems that
we made the mistake.
We only want to use SHAPE-files with geographic coordinates (they work with
ArcView), and displaying
them in ETRS89 (EPSG:25833) or alternatively geographic coordinates
(EPSG:4326).
Did you have an idea what's going wrong ?
Regards
Ellen
GEOdnm100.map:
NAME BRANDENBURG
STATUS ON
SIZE 200 200
SYMBOLSET "symbols/line.sym"
FONTSET "fonts/fonts.txt"
EXTENT 3240000.0 5679000.0 3490000.0 5946000.0
# EXTENT 11.25 51.30 14.80 53.60
UNITS meters
SHAPEPATH "geo"
PROJECTION
"init=EPSG:25833"
END
WEB
TEMPLATE map.html
MINSCALE 1
MAXSCALE 150000000
IMAGEPATH "...
IMAGEURL "...
METADATA
"wms_title" "...
"wms_abstract" "...
"wms_onlineresource"
"http://10.133.4.212:81/cgi-bin-wms/wms110?map=wms/GEOdnm100.map"
"wms_srs" "EPSG:4326,EPSG:25833"
"wms_fees" "...
"wms_keywordlist" "...
END
END
LAYER
METADATA
"wms_title" "Brandenburg"
"wms_srs" "EPSG:4326"
END
NAME state
MINSCALE 1
MAXSCALE 150000000
TYPE POLYGON
DATA geo_dnmvg_kreis
STATUS default
CLASSITEM 'GN'
CLASS
NAME "Brandenburg"
EXPRESSION /./
COLOR 255 255 224
OUTLINECOLOR 0 0 0
END
PROJECTION
"init=EPSG:4326"
END
END
wms110:
#!/bin/bash
export LD_LIBRARY_PATH=/usr/local/lib
export PROJ_DEBUG=YES
export PROJ_LIB=/usr/local/httpd/cgi-bin-wms
../mapserv $*
error_log:
pj_open_lib(proj_def.dat): call
fopen(/usr/local/httpd/cgi-bin-wms/proj_def.dat).
pj_open_lib(EPSG): call fopen(/usr/local/httpd/cgi-bin-wms/EPSG).
pj_open_lib(epsg): call fopen(/usr/local/httpd/cgi-bin-wms/epsg).
access_log:
10.133.4.999 - - [06/May/2003:12:44:18 +0200] "GET
/cgi-bin-wms/wms110?map=wms/GEOdnm100.map&SERVICE=WMS&V
ERSION=1.1.0&REQUEST=GetMap&LAYERS=state&STYLES=default&TRANSPARENT=FALSE&FO
RMAT=image/png&EXCEPTIONS=appl
ication/vnd.ogc.se_inimage&SRS=EPSG:4326&WIDTH=200&HEIGHT=200&BBOX=13.205910
0,52.2080300,13.2436100,52.222
6100 HTTP/1.0" 200 144
shell_wrapper:
export
QUERY_STRING=$'map=wms/GEOdnm100.map&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMa
efault&TRANSPARENT=FALSE&FORMAT=image/png&EXCEPTIONS=application/vnd.ogc.se_
0&HEIGHT=200&BBOX=13.2059100,52.2080300,13.2436100,52.2226100'
export REQUEST_METHOD=GET
mapserv > ms.out 2> ms.err
echo $? > ms.result
