[Mapserver-users] Oracle spatial
Bart van den Eijnden
bartvde at xs4all.nl
Tue May 6 15:26:23 EDT 2003
Hi list,
Frank thanks for the quick answer.
Which of the two options is the recommended one? Have there been any
performance tests in the past? Is one implementation more elaborate than
the other? Are there any future plans to not further develop one of the two
options, or will they be both available in future releases?
A lot of questions, I hope I get some answers.
Thanks,
Bart
On Tue, 06 May 2003 15:20:46 -0400, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> Bart van den Eijnden wrote:
>> Hi list,
>> I have a question about the Oracle Spatial support in mapserver.
>> There used to be (or still is) a C source file for Oracle support. But
>> now OGR is completely integrated with mapserver, is the Oracle Spatial
>> support from OGR used instead?
> Bart,
> "Normal" Oracle Spatial support in MapServer is still the built-in
> support
> implemented in maporaclespatial.cpp. Which you use depends on how you
> build mapserver, and OGR, and what you use in your mapfile. To use OGR
> based oracle spatial support you would need to use a CONNECTIONTYPE of
> OGR.
> Best regards,
