[Mapserver-users] problems compiling PROJ.4 on Mac OS X 10.2.5
Daniel Morissette
morissette at dmsolutions.ca
Tue May 6 19:03:02 EDT 2003
John Oram wrote:
> I'm a bit confused why proj.4 is built using "sh install" while
> everything else uses "make install". Also, how case sensitive are the
> references? I notice references to PROJ.4, Proj.4 and proj.4.
Maybe there is something specific to MacOSX that I'm not aware of, but
I've always compiled/installed PROJ using './configure; make; sudo make
install' on any OS. I never used 'sh install' ... perhaps you could try
'make install' and see if that works for you.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
