[Mapserver-users] problems compiling PROJ.4 on Mac OS X 10.2.5
John Oram
mapserver at oram.com
Tue May 6 19:46:10 EDT 2003
OK, tried "sudo make install". Seems a little better -- no grievous
errors that I can see (though I am not quite sure what I should look
for). I did see something about "nad2nad source files not present" --
is there an acid test, i.e. certain things I should look for to see if
it installed properly? In /usr/local/lib I see:
libproj.0.4.1.dylib
libproj.0.dylib
libproj.a
libproj.dylib
libproj.la
These have timestamps that make sense. Will try PHP next and see what
happens.
Thanks,
John
On Tuesday, May 6, 2003, at 04:03 PM, Daniel Morissette wrote:
> John Oram wrote:
>> I'm a bit confused why proj.4 is built using "sh install" while
>> everything else uses "make install". Also, how case sensitive are the
>> references? I notice references to PROJ.4, Proj.4 and proj.4.
> Maybe there is something specific to MacOSX that I'm not aware of, but
> I've always compiled/installed PROJ using './configure; make; sudo make
> install' on any OS. I never used 'sh install' ... perhaps you could
> try
> 'make install' and see if that works for you.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
