[Mapserver-users] rojection library error. no system list, errno:
2
Frank Warmerdam
warmerdam at pobox.com
Thu May 8 12:51:38 EDT 2003
Benjamin Thelen wrote:
> Hi Frank,
> thanks to you. Sorry for that long mail again, I am still stuck and could
> not find any more helpful information in the mailing list archives or at
> MapServerWiki.
> shp2img responds the same error message!!
> root at qwertzuiop# /usr/home/src/mapserver-3.6.5/shp2img -m
> /usr/home/umn/test1.map -o /tmp/test
> pj_open_lib(proj_def.dat): call fopen(/usr/local/share/proj/proj_def.dat).
> pj_open_lib(EPSG): call fopen(/usr/local/share/proj/EPSG).
> msProcessProjection(): Projection library error. no system list, errno: 2
Benjamin,
The thing that sticks out above is that the system is trying to open
is "EPSG" not "epsg". That is, uppercase instead of lower case.
As a first test, try copying /usr/local/share/proj/epsg to
/usr/local/share/proj/EPSG and see if that helps. If so, we still
should figure out where the wrong case is coming from.
> PROJECTION
> "init=EPSG:31493"
> END
Well, that's it. You should use "init=epsg:31493".
The no system error list just means that as built PROJ.4 doesn't know how
to translate error "2" into the "file not found" message that corresponds
to it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
