[Mapserver-users] rojection library error. no system list, errno: 2
Benjamin Thelen
benjamin.thelen at ccgis.de
Fri May 9 08:06:43 EDT 2003
Hey Frank, we got it!!! UMN is running with postgis and proj4 finally works,
too!
Thank you very much for your patient help! :-)
I don't understand why an installed proj4 looks for EPSG and not for epsg. I
mean, who the hell made that installation routine? Ah, maybe for learning
purposes...find the bug?! ;-))
All right, thanks again to you.
Ah, I forgot, why should I use "init=epsg:31493" instead of "...EPSG...".
Our umn projects seem to run well with "...EPSG...".
Benjamin
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Thursday, May 08, 2003 6:52 PM
> To: Benjamin Thelen
> Cc: UMN MapServer
> Subject: Re: [Mapserver-users] rojection library error. no system list,
> errno: 2
> Benjamin Thelen wrote:
> > Hi Frank,
> > thanks to you. Sorry for that long mail again, I am still stuck
> and could
> > not find any more helpful information in the mailing list archives or at
> > MapServerWiki.
> > shp2img responds the same error message!!
> > root at qwertzuiop# /usr/home/src/mapserver-3.6.5/shp2img -m
> > /usr/home/umn/test1.map -o /tmp/test
> > pj_open_lib(proj_def.dat): call
> fopen(/usr/local/share/proj/proj_def.dat).
> > pj_open_lib(EPSG): call fopen(/usr/local/share/proj/EPSG).
> > msProcessProjection(): Projection library error. no system
> list, errno: 2
> Benjamin,
> The thing that sticks out above is that the system is trying to open
> is "EPSG" not "epsg". That is, uppercase instead of lower case.
> As a first test, try copying /usr/local/share/proj/epsg to
> /usr/local/share/proj/EPSG and see if that helps. If so, we still
> should figure out where the wrong case is coming from.
> > PROJECTION
> > "init=EPSG:31493"
> > END
> Well, that's it. You should use "init=epsg:31493".
> The no system error list just means that as built PROJ.4 doesn't know how
> to translate error "2" into the "file not found" message that corresponds
> to it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
