[Mapserver-users] Anyone dong Flash?
Vincent Schut schut at sarvision.com
Mon May 12 06:25:10 PDT 2003
Did some flash experiments. Source code is not free I'm afraid, but I could
certainly share experience if you have certain questions about getting flash
& mapserver to work.
For an example of a simple viewer:
http://www.sarvision.nl/mawas/mapserver/ms-mawas.php ; showing a landsat
image of an area in Kalimantan, Indonesia. Have been experimenting with the
multi-layer flash output but don't have any suitable swf's using this to show
you.
Have made nothing with real GIS functionality, or even queries. Though I have
had some thoughts on how I could implement that in flash.
Btw, all is made using php/ming and mapserver/mapscript.
But, if you don't need to have on the fly swf apps but can have a static one,
and if you can do C, I'd recommend to start writing in c/ming because using
php and the latest ming (0.3a) is a real pain. And 0.3a has quite some bugs
fixed that 0.2a (which was the best version I managed to run with php) still
has.
Cheers,
Vincent Schut.
On Friday 02 May 2003 16:28, Howard Mark wrote:
> A co-worker is trying to write a GIS interface with Flash. He does have
> panning and zooming working for a single fixed WMS layer. However there's a
> lot of work to do to get the interface to do what mapserver does out of the
> box. I thought I'd ask if anyone here is doing similar development or wants
> to share development?
> Mark
>***** This message is intended only for the use of the Addressee and may
> contain information that is PRIVILEGED and CONFIDENTIAL.
> If you are not the intended recipient, you are hereby notified that any
> dissemination of this communication is strictly prohibited. If you have
> received this communication in error, please erase all copies of the
> message and its attachments and notify Space Imaging immediately.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
More information about the MapServer-users mailing list
