[Mapserver-users] Mapplet/jBox problems
Ioannis Kanellopoulos
ioannis.kanellopoulos at jrc.it
Mon May 12 09:40:06 EDT 2003
Richard,
Thank you for your mail and suggestion. I have tested the jBox with IE6
and unfortunately I have exactly the same behaviour. i.e. non automatic
redraw even thought the if(redraw) ...is there.
(I have also read your modified How to).
cheers
yannis
Richard Greenwood wrote:
> I have updated the doc's for jBox. Until I get them posted you can
> read them at:
> http://www.greenwoodmap.com/mapserver/jBox/jBox_docbook.html
> I have had some trouble with Mozilla. To better isolate your problem,
> can you test with MS IE or Netscape 4.x?
> Rich
> At 02:23 PM 5/12/2003 +0200, you wrote:
>> Hi All,
>> I am trying to use the mapplet or jBox java utilities for mapserver.
>> I have run into the following problems:
>> 1. mapplet: cannot make box on/off to work properly. Following the
>> instructions of "Mapplet How to" I have added the
>> onClick="document.mapplet.boxoff()" or boxon respectively for
>> zoomout,pan and zoomin. I have also initialised
>> <param name="box" value=off"> in the applet. Problem is that it does
>> not work the second time round. for e.g. if I want to zoomin for a
>> second time without selecting the radio button then it goes back to
>> boxoff as it is initialised. teh same is true with zoomout and pon if
>> the box is initialised as on.
>> 2. jBox: Here the problem is that I cannot make it to perform the
>> redraw without hitting the refresh button again. this even after I
>> have added the "if (redraw) { document.mapserv.submit();}" at the end
>> of the setbox_handler() function. If I just change the function names
>> to the ones for mapplet it works properly.
>> I have mapserver 3.6.5 compiled in a Redhat 8.0, browser Mozilla
>> 1.0.1 but I encouner the mapplet problem also with Windows2000 with
>> apache 2 server and Mozilla 1.3. I am also using the standard demo
>> files for these experiments.
>> Any help will be greatly appreciated.
>> thanks a lot
>> yannis
>> EC-Joint Research Centre
>> Institute for Environment and Sustainability
>> TP 262
>> 21020 Ispra(VA)
>> Italy
>> email: ioannis.kanellopoulos at jrc.it
>> www: http://www.jrc.cec.eu.int,
>> http://www.ec-gis.org, http://gi-gis.jrc.it
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> (307) 733-0203
> Rich at GreenwoodMap.com
> www.GreenwoodMap.com
TP 262
21020 Ispra(VA)
Italy
