[Mapserver-users] Mapplet/jBox problems
Richard Greenwood
rich at greenwoodmap.com
Mon May 12 09:13:45 EDT 2003
--=======17443D2E=======
Content-Type: text/plain; x-avg-checked=avg-ok-5248D2A; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
I have updated the doc's for jBox. Until I get them posted you can read
them at:
http://www.greenwoodmap.com/mapserver/jBox/jBox_docbook.html
I have had some trouble with Mozilla. To better isolate your problem, can
you test with MS IE or Netscape 4.x?
Rich
At 02:23 PM 5/12/2003 +0200, you wrote:
>Hi All,
>I am trying to use the mapplet or jBox java utilities for mapserver. I
>have run into the following problems:
>1. mapplet: cannot make box on/off to work properly. Following the
>instructions of "Mapplet How to" I have added the
>onClick="document.mapplet.boxoff()" or boxon respectively for zoomout,pan
>and zoomin. I have also initialised
><param name="box" value=off"> in the applet. Problem is that it does not
>work the second time round. for e.g. if I want to zoomin for a second time
>without selecting the radio button then it goes back to boxoff as it is
>initialised. teh same is true with zoomout and pon if the box is
>initialised as on.
>2. jBox: Here the problem is that I cannot make it to perform the
>redraw without hitting the refresh button again. this even after I have
>added the "if (redraw) { document.mapserv.submit();}" at the end of the
>setbox_handler() function. If I just change the function names to the ones
>for mapplet it works properly.
>I have mapserver 3.6.5 compiled in a Redhat 8.0, browser Mozilla 1.0.1 but
>I encouner the mapplet problem also with Windows2000 with apache 2 server
>and Mozilla 1.3. I am also using the standard demo files for these experiments.
>Any help will be greatly appreciated.
>thanks a lot
>yannis
>Ioannis Kanellopoulos
>EC-Joint Research Centre
>Institute for Environment and Sustainability
>TP 262
>21020 Ispra(VA)
>Italy
>email: ioannis.kanellopoulos at jrc.it
>www: http://www.jrc.cec.eu.int,
>http://www.ec-gis.org, http://gi-gis.jrc.it
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
--=======17443D2E=======--
