[Mapserver-users] Linux segmentation problem
Björn Platzen
bplatzen at sosnetz.de
Tue May 13 07:47:27 EDT 2003
Hi Matthew,
> However, if I pass any parameters at all, be they in mapserver, WMS
> or WFS format, I get an internal server error. The error log says
> only "premature end of script", and if I run mapserv at the command
> line by passing a QUERY_STRING here, I get "segmentation fault".
I had a similar problem and could find out what went wrong the shp2img
program, that was compiled with mapserver. Run it on a shell with your
mapfile (e.g. shp2img -m mapfile.map -o output.png) and see, if there
are any errors. If yes, I think, that the same errors will happen using
the mapserv CGI.
hth,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
