[Mapserver-users] Linux segmentatio n problem
Hatcher Matthew
MJHATCHER at qinetiq.com
Tue May 13 08:00:46 EDT 2003
Hi Bjoern,
Thanks for your suggestion, but unfortunately, shp2img runs fine without any
errors!
I don't think mapserv is actually getting as far as reading the map file,
because I get a segmentation fault whether I specify a valid map file or
not. I'm pretty sure it's not that it can't find some shared libraries, as
they normally complain that they are missing when you do "mapserv -v".
Any more ideas?!
Matt.
-----Original Message-----
From: Björn Platzen [mailto:bplatzen at sosnetz.de]
Sent: 13 May 2003 12:47
To: Hatcher Matthew; 'mapserver-users at lists.gis.umn.edu'
Subject: Re: [Mapserver-users] Linux segmentation problem
Hi Matthew,
> However, if I pass any parameters at all, be they in mapserver, WMS
> or WFS format, I get an internal server error. The error log says
> only "premature end of script", and if I run mapserv at the command
> line by passing a QUERY_STRING here, I get "segmentation fault".
I had a similar problem and could find out what went wrong the shp2img
program, that was compiled with mapserver. Run it on a shell with your
mapfile (e.g. shp2img -m mapfile.map -o output.png) and see, if there
are any errors. If yes, I think, that the same errors will happen using
the mapserv CGI.
hth,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information
is prohibited and may be unlawful.
Emails and other electronic communication with QinetiQ may be monitored.
Calls to our Customer Contact Centre may be recorded for quality control,
regulatory and monitoring purposes.
