[Mapserver-users] Linux segmentation problem
Vincent Schut
schut at sarvision.com
Tue May 13 10:22:24 EDT 2003
Just confirmed this with latest cvs. Both mapserv and mapscript crash upon the
simples request.
According to gdb it seems to be something in cgiutil.c...
I filed a bug in bugzilla and will post a message on the mapserver-dev list.
Cheers,
Vincent.
On Tuesday 13 May 2003 12:54, Hatcher Matthew wrote:
> Hi all,
> I have compiled and built the latest nightly build of Mapserver 3.7 (or 4.0
> as it announces itself) using Red Hat Linux 9.0.
> I used the instructions given in the Wiki - for which I'm very grateful.
> Thanks to the authors!
> Mapserver and all the associated libraries compile absolutely fine - I used
> the following options:
> ./configure
> --without-tiff
> --without-eppl
> --without-jpeg
> --with-threads
> --with-proj
> --with-gdal=/usr/local/bin
> --with-gd=/usr/local
> --with-freetype=/usr/bin
> --with-ogr
> --with-wmsclient
> --with-wms
> --with-wfsclient
> --with-wfs
> ./mapserv -v
> MapServer version 4.0 (development) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> Running mapserv through a browser with no parameters works fine
> (http://localhost/cgi-bin/mapserv). This returns the standard html saying
> "no query information to decode".
> However, if I pass any parameters at all, be they in mapserver, WMS or WFS
> format, I get an internal server error. The error log says only "premature
> end of script", and if I run mapserv at the command line by passing a
> QUERY_STRING here, I get "segmentation fault".
> Helpful. Anybody got any suggestions, or ways in which I can debug a bit to
> find out what is causing the problem?
> Cheers,
> Matt
> The Information contained in this E-Mail and any subsequent correspondence
> is private and is intended solely for the intended recipient(s).
> For those other than the recipient any disclosure, copying, distribution,
> or any action taken or omitted to be taken in reliance on such information
> is prohibited and may be unlawful.
> Emails and other electronic communication with QinetiQ may be monitored.
> Calls to our Customer Contact Centre may be recorded for quality control,
> regulatory and monitoring purposes.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
