[Mapserver-users] Linux segmentatio n problem
m.spring at gmx.de
m.spring at gmx.de
Tue May 13 10:01:37 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hatcher Matthew <MJHATCHER at qinetiq.com> writes:
> Hi all,
> In that case, could someone please post the URL of an older copy of
> nightly.tgz so I can test if that suffers from the same problem. I don't
Checked out from CVS with
cvs -d:pserver:cvs at mapserver.gis.umn.edu:/data2/cvsroot -z3 checkout -D "2003-05-01" mapserver
You can download it from
http://dream.lrrl.arch.tu-muenchen.de/~springm/mapserver/mapserver-dev-20030501.tgz
I configured it with
./configure \
--without-pdf \
--without-tiff \
--with-zlib \
--with-jpeg \
--with-freetype \
--with-threads \
--with-gd=/build/server/gd-2.0.12gif \
--with-gdal=/usr/local/bin/gdal-config \
--with-ogr=/usr/local/bin/gdal-config \
--with-proj=/build/server/proj-4.4.5 \
--enable-debug
and it runs without segfault.
Note that you can test the cgi on the commandline with those commands:
# export REQUEST_METHOD=GET
# export QUERY_STRING="map=/data/web/rgu_intern/radlmap/radlmap.dfo.map&mode=map"
# mapserv | sed '1,2d' | display
assumed that you have mapserv in your directory or in your path and -->
you have 'display' to read image data from STDIN
Hope this helps
Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 and Gnu Privacy Guard <http://www.gnupg.org/>
iD8DBQE+wPrBxxUzQSse11ARAn0UAJwPGYysHcjeyKpxKlWjyXLbUTa2pACggSCP
1Z4W0SXvZCcyxI/fMGvutRQ=
=dz2e
-----END PGP SIGNATURE-----
