[Mapserver-users] Please Help me
Palle Due Larsen
palle at mail-online.dk
Tue May 13 11:33:45 EDT 2003
Hi Andrea,
Just enter mapserv -query_string="(all your normal CGI parameters)"
Best regards
Palle Due Larsen
-----Original Message-----
To: "Palle Due Larsen" <palle at mail-online.dk>
Cc: mapserver-users at lists.gis.umn.edu
Date: Mon, 12 May 2003 09:51:09 +0200
Subject: Re: [Mapserver-users] Please Help me
> Palle,
> could you write me a text to use in mapserv from command line, I'm
> not able
> to translate an url to a text for the command line. I know only
> "mapserv
> -v".
> Thank you,
> Andrea
> | | "Palle Due |
> | | Larsen" |
> | | <palle at mail-onli|
> | | ne.dk> |
> | | 12/05/2003 09.48|
> | Per: aborruso at spaziogis.it
> | Cc:
> | Oggetto: Re: [Mapserver-users] Please Help me
> Yes, I am aware of that, it was just that your url looked a little
> funny, so I thought it might be that mapserver misunderstood
> something.
> However, I just checked with my installation (Win2000, IIS, ms3.6),
> and
> I get expected results when using your url, so it must be something
> else. Have you tried running mapserv.exe from the command-line - with
> those parameters - to see if it's returning a correct result?
> Best regards
> Palle
> From: aborruso at spaziogis.it
> Date: Mon, 12 May 2003 09:19:58 +0200
> > Palle,
> > as you can read in my past email, the map file I want to use in my
> > example
> > does not exist. Then it would be normal to have an error message,
> but
> > I
> > remember some more specific error messages with the old version.
> Then
> > in my
> > example it should be appeared a message like: "mapserv: impossible
> to
> > find
> > test.map". I have instead: "CGI Error The specified CGI application
> > misbehaved by not returning a complete set of HTTP headers. The
> > headers it
> > did return are:".
> > Is this error message normal or is there something wrong in my
> > installation??
> > Thank you,
> > Andrea
> > | | "Palle Due |
> > | | Larsen" |
> > | | ne.dk> |
> > | | 12/05/2003 09.09|
> > | Per: aborruso at spaziogis.it,
> > | Cc:
> > Could it be that the url is wrong? Your are missing the map
> > parameter,
> > try this:
> > http://127.0.0.1/cgi-bin/mapserv.exe?map=C:
> > \Inetpub\wwwroot\mapserver\test.map&mode=map
> > Best Regards
> > Palle Due Larsen
> > Carl Bro GIS & IT
> > To: mapserver-users at lists.gis.umn.edu
> > Date: Thu, 8 May 2003 19:27:14 +0200
> > Subject: [Mapserver-users] Please Help me
> > > Dear users,
> > > some time ago I have learned to build a mapserver powered site
> (3.2
> > > version). In the last months I have not had the time to "study"
> the
> > > new
> > > version and features of mapserver.
> > > Here is my problem. I have tried to build an update manifold
> > powered
> > > site.
> > > I have downloaded ms36gif_gdal_pg_wms.zip and ms35_libs.zip, then
> I
> > > have
> > > extracted all files where they could be extracted and then I have
> > > made a
> > > simple test; I have written simply this URL:
> > > http://127.0.0.1/cgi-bin/mapserv.exe?=C:
> > > \Inetpub\wwwroot\mapserver\test.map&mode=map.
> > > I have this error message: "CGI Error The specified CGI
> application
> > > headers it
> > > did return are:"
> > > The file of the test url does not exist, but I remember that with
> > the
> > > old
> > > versions I had an error message like "it's impossible to access
> to
> > > the file
> > > ..." (or something similar), instead I have a generic strange
> error
> > > message
> > > and I think there is something strong in my mapserver
> installation.
> > > Do you have some tip or advice for me?
> > > I have winxp pro with IIS.
> > > Thank you very much,
> > > Andrea
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Få en gratis emailkonto her: www.mail-online.dk
> > Deltag i en lille brugerundersøgelse på
> > nettet, og vind et gavekort på 50.000 kroner..!
> > www.directoffice.dk/konkurrence
