[Mapserver-users] Please Help me
aborruso at spaziogis.it
Mon May 12 03:51:09 EDT 2003
Palle,
could you write me a text to use in mapserv from command line, I'm not able
to translate an url to a text for the command line. I know only "mapserv
-v".
Thank you,
Andrea
| | "Palle Due |
| | Larsen" |
| | <palle at mail-onli|
| | ne.dk> |
| | 12/05/2003 09.48|
| Per: aborruso at spaziogis.it |
| Cc: |
| Oggetto: Re: [Mapserver-users] Please Help me |
Yes, I am aware of that, it was just that your url looked a little
funny, so I thought it might be that mapserver misunderstood something.
However, I just checked with my installation (Win2000, IIS, ms3.6), and
I get expected results when using your url, so it must be something
else. Have you tried running mapserv.exe from the command-line - with
those parameters - to see if it's returning a correct result?
Best regards
Palle
-----Original Message-----
To: "Palle Due Larsen" <palle at mail-online.dk>
Date: Mon, 12 May 2003 09:19:58 +0200
Subject: Re: [Mapserver-users] Please Help me
> Palle,
> as you can read in my past email, the map file I want to use in my
> example
> does not exist. Then it would be normal to have an error message, but
> I
> remember some more specific error messages with the old version. Then
> in my
> example it should be appeared a message like: "mapserv: impossible to
> find
> test.map". I have instead: "CGI Error The specified CGI application
> misbehaved by not returning a complete set of HTTP headers. The
> headers it
> did return are:".
> Is this error message normal or is there something wrong in my
> installation??
> Thank you,
> Andrea
> | | "Palle Due |
> | | Larsen" |
> | | ne.dk> |
> | | 12/05/2003 09.09|
> | Per: aborruso at spaziogis.it,
> mapserver-users at lists.gis.umn.edu
> | Cc:
> Could it be that the url is wrong? Your are missing the map
> parameter,
> try this:
> http://127.0.0.1/cgi-bin/mapserv.exe?map=C:
> \Inetpub\wwwroot\mapserver\test.map&mode=map
> Best Regards
> Palle Due Larsen
> Carl Bro GIS & IT
> From: aborruso at spaziogis.it
> To: mapserver-users at lists.gis.umn.edu
> Date: Thu, 8 May 2003 19:27:14 +0200
> Subject: [Mapserver-users] Please Help me
> > Dear users,
> > some time ago I have learned to build a mapserver powered site (3.2
> > version). In the last months I have not had the time to "study" the
> > new
> > version and features of mapserver.
> > Here is my problem. I have tried to build an update manifold
> powered
> > site.
> > I have downloaded ms36gif_gdal_pg_wms.zip and ms35_libs.zip, then I
> > have
> > extracted all files where they could be extracted and then I have
> > made a
> > simple test; I have written simply this URL:
> > http://127.0.0.1/cgi-bin/mapserv.exe?=C:
> > \Inetpub\wwwroot\mapserver\test.map&mode=map.
> > I have this error message: "CGI Error The specified CGI application
> > headers it
> > did return are:"
> > The file of the test url does not exist, but I remember that with
> the
> > old
> > versions I had an error message like "it's impossible to access to
> > the file
> > ..." (or something similar), instead I have a generic strange error
> > message
> > and I think there is something strong in my mapserver installation.
> > Do you have some tip or advice for me?
> > I have winxp pro with IIS.
> > Thank you very much,
> > Andrea
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Få en gratis emailkonto her: www.mail-online.dk
> Deltag i en lille brugerundersøgelse på
> nettet, og vind et gavekort på 50.000 kroner..!
> www.directoffice.dk/konkurrence
