[Mapserver-users] OracleSpatial switches to include...(correction)
    Jesiel de Souza
    jesiel at cttmar.univali.br
    Tue May 13 10:22:06 PDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_013B_01C3195B.084D2E20
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Richard,
First execute "nmake /f makefile.vc clean" for to clean all compilation =
(*.obj, *.lib, ... ).
Modify your "nmake.opt" as the lines bellow ( indicated in the blue =
color ):
At line 203:
# Optional ORACLESPATIAL Support. Contact: cabral at cttmar.univali.br
ORACLESPATIAL=3D-DUSE_ORACLESPATIAL
ORACLESPATIAL_HOME=3Dc:/oracle/ora82
ORACLESPATIAL_LIB=3D$(ORACLESPATIAL_HOME)/oci/lib/msvc/oci.lib
ORACLESPATIAL_INC=3D-I$(ORACLESPATIAL_HOME)/oci/include
At line 459:
LIBS=3D$(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
     $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
     $(CURL_LIB) $(ECW_LIB) $(MING_LIB) $(PDF_LIB) \
     $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
     $(XERCES_LIB) $(ORACLESPATIAL_LIB)
INCLUDES=3D$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
         $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
         $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
         $(IMGGEN_INC) $(ERR_INC) $(ORACLESPATIAL_INC)
MS_CFLAGS=3D$(INCLUDES) $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
          $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
          $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA) $(GDAL) \
          -DFEATURE_INFO_HTML $(WFS) $(WFSCLIENT) $(PDF) $(EGIS) =
$(ORACLESPATIAL)
Be sure you modified the variables LIBS, INCLUDES and MS_CFLAGS =
correctly.
If you run into trouble, please send me the error message/output.
Regards,
Jesiel de Souza
  ----- Original Message -----=20
  To: Jesiel de Souza=20
  Sent: Tuesday, May 13, 2003 11:10 AM
  Subject: RE: [Mapserver-users] OracleSpatial switches to =
  Hi Jesiel,
  =20
  I did what you told me.  I had to adjust the way I declared the =
variables:
  =20
  ORACLESPATIAL_LIB=3D$(ORACLESPATIAL_HOME)/lib/oracore8.lib =
$(ORACLESPATIAL_HOME)/lib/oraxml8.lib \
                    $(ORACLESPATIAL_HOME)/lib/oraxmlg8.lib
  ORACLESPATIAL_INC=3D-I$(ORACLESPATIAL_HOME)/rdbms/demo
  =20
  =20
  It would not compile when I had the syntax you gave me:
  ORACLESPATIAL=3D      -DUSE_ORACLESPATIAL
  ORACLESPATIAL_HOME=3D c:\oracle\ora817
  ORACLESPATIAL_LIB=3D  -L$(ORACLESPATIAL_HOME)/lib -lclntsh
  ORACLESPATIAL_INC=3D  -I$(ORACLESPATIAL_HOME)/rdbms/demo =
-I$(ORACLESPATIAL_HOME)/rdbms/public
  =20
  =20
  The compiler did not like the -L or the -lclntsh switches under =
ORACLESPATIAL_LIB.So instead I referenced the 3 lib files found in the =
lib directory.
  =20
  Anyway, I still do not get ORACLESPATIAL listed as an input...
  =20
  Here is what I do get:
  =20
  =20
  C:\projects\mapserver>mapserv -v
  MapServer version 4.0 (development) OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP OUTPUT=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREE
  TYPE SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER =
SUPPORTS=3DWFS_CLIENT INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE
  =20
  Any other suggestions?
  =20
  Cheers,
  =20
  Richard
  =20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:v =3D=20
"urn:schemas-microsoft-com:vml" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word" xmlns:st1 =3D=20
"urn:schemas-microsoft-com:office:smarttags"><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C31937.E40D04E0" =
rel=3DFile-List><o:SmartTagType=20
name=3D"time"=20
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"></o:SmartTagT=
ype><o:SmartTagType=20
name=3D"date"=20
ype><!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<STYLE>st1\:* {
	BEHAVIOR: url(#default#ieooui)
</STYLE>
<![endif]-->
<STYLE>
 /* Font Definitions */
 @font-face
	{font-family:Tahoma;
	panose-1:2 11 6 4 3 5 4 4 2 4;
	mso-font-charset:0;
	mso-generic-font-family:swiss;
	mso-font-pitch:variable;
	mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
	{margin:0in;
	font-size:12.0pt;
p
	{mso-margin-top-alt:auto;
	margin-right:0in;
	mso-margin-bottom-alt:auto;
	margin-left:0in;
	font-size:12.0pt;
span.EmailStyle19
	{mso-style-type:personal;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.EmailStyle20
	font-family:Arial;
	color:navy;}
span.EmailStyle21
	font-family:Arial;
	color:navy;}
span.EmailStyle22
	font-family:Arial;
	color:navy;}
span.EmailStyle23
	font-family:Arial;
	color:navy;}
span.EmailStyle25
	{mso-style-type:personal-reply;
	font-family:Arial;
	color:navy;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
span.GramE
	{mso-style-name:"";
	mso-gram-e:yes;}
@page Section1
	{size:8.5in 11.0in;
	margin:1.0in 1.25in 1.0in 1.25in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</STYLE>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0in 5.4pt 0in 5.4pt;
	mso-para-margin:0in;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
 <o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
 <o:shapelayout v:ext=3D"edit">
  <o:idmap v:ext=3D"edit" data=3D"1" />
 </o:shapelayout></xml><![endif]--></HEAD>
<BODY lang=3DEN-US style=3D"tab-interval: .5in" vLink=3Dpurple =
link=3Dblue=20
bgColor=3Dwhite>
<DIV><FONT face=3DArial size=3D2>Hi Richard,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>First execute "<FONT face=3DArial =
size=3D2>nmake /f=20
makefile.vc clean" for to clean all compilation (*.obj, *.lib, ...=20
).</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Modify your "nmake.opt" as the lines =
bellow (=20
indicated in the blue color ):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><STRONG>At line =
203:</STRONG></FONT></DIV>
<DIV><FONT face=3DArial><FONT color=3D#808080 size=3D1># Optional =
ORACLESPATIAL=20
Support. Contact: </FONT><A =
href=3D"mailto:cabral at cttmar.univali.br"><FONT=20
color=3D#808080 size=3D1>cabral at cttmar.univali.br</FONT></A><BR><FONT=20
color=3D#808080><FONT=20
size=3D1>ORACLESPATIAL=3D-DUSE_ORACLESPATIAL<BR>ORACLESPATIAL_HOME=3Dc:/o=
racle/ora82<BR>ORACLESPATIAL_LIB=3D<FONT=20
color=3D#0000ff>$(ORACLESPATIAL_HOME)/oci/lib/msvc/oci.lib</FONT><BR>ORAC=
LESPATIAL_INC=3D<FONT=20
color=3D#0000ff>-I$(ORACLESPATIAL_HOME)/oci/include</FONT></FONT></FONT><=
/FONT></DIV>
459:</STRONG></FONT></DIV>
<DIV></FONT><FONT face=3DArial color=3D#808080><FONT =
size=3D1>LIBS=3D$(MS_LIB) $(GD_LIB)=20
$(TIFF_LIB) $(JPEG_LIB) \<BR>     $(PROJ_LIB) =
$(OGR_LIB)=20
$(GDAL_LIB)\<BR>     $(CURL_LIB) $(ECW_LIB) =
$(MING_LIB)=20
$(PDF_LIB) \<BR>     $(WINSOCK_LIB) $(POSTGIS_LIB)=20
$(IMGGEN_LIB) $(ERR_LIB) \<BR>     $(XERCES_LIB) =
<FONT=20
color=3D#0000ff>$(ORACLESPATIAL_LIB)</FONT></FONT></FONT></DIV></DIV>
<DIV><FONT color=3D#808080 size=3D1></FONT> </DIV>
<DIV><FONT face=3DArial color=3D#808080><FONT =
size=3D1>INCLUDES=3D$(GD_INC) $(TIFF_INC)=20
$(JPEG_INC) \<BR>         =
$(PROJ_INC)=20
$(REGEX_INC) $(GDAL_INC) $(OGR_INC)=20
\<BR>         $(CURL_INC) =
$(MING_INC)=20
$(PDF_INC) $(POSTGIS_INC) =
\<BR>        =20
$(IMGGEN_INC) $(ERR_INC) <FONT=20
color=3D#0000ff>$(ORACLESPATIAL_INC)</FONT></FONT></FONT></DIV>
size=3D1>MS_CFLAGS=3D$(INCLUDES)=20
$(REGEX_OPT) $(STRINGS) $(POSTGIS)=20
\<BR>          $(EPPL) =
$(PROJ)=20
$(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)=20
\<BR>          $(WMSCLIENT) =
$(MING)=20
$(IGNORE_MISSING_DATA) $(GDAL)=20
\<BR>          =
-DFEATURE_INFO_HTML=20
$(WFS) $(WFSCLIENT) $(PDF) $(EGIS) <FONT=20
color=3D#0000ff>$(ORACLESPATIAL)</FONT></FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Be sure you modified the variables =
LIBS, INCLUDES=20
and MS_CFLAGS correctly.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If you run into trouble, please send me =
the error=20
message/output.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Jesiel de Souza</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> </DIV>
<DIV><BR></DIV></FONT>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
  <DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
  <DIV=20
  style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
  <A title=3DRichardBecher at SierraSystems.com=20
  href=3D"mailto:RichardBecher at SierraSystems.com">Becher, Richard</A> =
</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Djesiel at cttmar.univali.br=20
  href=3D"mailto:jesiel at cttmar.univali.br">Jesiel de Souza</A> </DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Tuesday, May 13, 2003 =
11:10=20
AM</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users]=20
  OracleSpatial switches to include...(correction)</DIV>
  <DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><BR></DIV>
  <DIV class=3DSection1>
  <P class=3DMsoNormal><FONT face=3DArial color=3Dnavy size=3D2><SPAN=20
  style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Hi=20
  Jesiel,<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: =
Arial"><o:p> </o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">I did what =
you told=20
  me.<SPAN style=3D"mso-spacerun: yes">  </SPAN>I had to adjust the =
way I=20
  declared the variables:<o:p></o:p></SPAN></FONT></P>
  <P class=3DMsoNormal style=3D"mso-layout-grid-align: none"><SPAN =
class=3DGramE><FONT=20
  face=3D"Courier New" size=3D2><SPAN=20
  style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"># Optional =
ORACLESPATIAL=20
  Support.</SPAN></FONT></SPAN><FONT face=3D"Courier New" size=3D2><SPAN =
  style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"> Contact: <A=20
href=3D"mailto:cabral at cttmar.univali.br">cabral at cttmar.univali.br</A><o:p=
  <P class=3DMsoNormal style=3D"mso-layout-grid-align: none"><FONT=20
  style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier =
New'">ORACLESPATIAL=3D-DUSE_ORACLESPATIAL<o:p></o:p></SPAN></FONT></P>
New'">ORACLESPATIAL_HOME=3Dc<SPAN=20
  class=3DGramE>:/</SPAN>oracle/ora82<o:p></o:p></SPAN></FONT></P>
New'">ORACLESPATIAL_LIB=3D$(ORACLESPATIAL_HOME)/lib/oracore8.lib=20
  $(ORACLESPATIAL_HOME)/lib/oraxml8.lib \<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><SPAN=20
  style=3D"mso-tab-count: =
3">           &nbs=
p;     =20
</SPAN>$(ORACLESPATIAL_HOME)/lib/oraxmlg8.lib<o:p></o:p></SPAN></FONT></P=
New'">ORACLESPATIAL_INC=3D-I$(ORACLESPATIAL_HOME)/<SPAN=20
  class=3DSpellE>rdbms</SPAN>/demo<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">It would =
not compile=20
  when I had the syntax you gave me:<o:p></o:p></SPAN></FONT></P>
  <P class=3DMsoNormal><SPAN class=3DGramE><FONT face=3DArial =
color=3Dblue size=3D1><SPAN=20
  style=3D"FONT-SIZE: 7.5pt; COLOR: blue; FONT-FAMILY: Arial"># Optional =
  ORACLESPATIAL Support.</SPAN></FONT></SPAN><FONT face=3DArial =
color=3Dblue=20
  size=3D1><SPAN style=3D"FONT-SIZE: 7.5pt; COLOR: blue; FONT-FAMILY: =
Arial">=20
  Contact: </SPAN></FONT><FONT face=3DArial><SPAN style=3D"FONT-FAMILY: =
Arial"><A=20
  href=3D"mailto:cabral at cttmar.univali.br"><FONT size=3D1><SPAN=20
  style=3D"FONT-SIZE: =
7.5pt">cabral at cttmar.univali.br</SPAN></FONT></A><BR></SPAN></FONT><FONT =
  face=3DArial color=3Dblue size=3D1><SPAN=20
Arial">ORACLESPATIAL=3D     =20
  -DUSE_ORACLESPATIAL<BR>ORACLESPATIAL_HOME=3D=20
  c:\oracle\ora817<BR>ORACLESPATIAL_LIB=3D<SPAN class=3DGramE> =20
  -</SPAN>L$(ORACLESPATIAL_HOME)/lib -<SPAN=20
  class=3DSpellE>lclntsh</SPAN><BR>ORACLESPATIAL_INC=3D<SPAN =
class=3DGramE> =20
  -</SPAN>I$(ORACLESPATIAL_HOME)/<SPAN class=3DSpellE>rdbms</SPAN>/demo=20
  class=3DSpellE>rdbms</SPAN>/public<o:p></o:p></SPAN></FONT></P>
  <P class=3DMsoNormal><FONT face=3DArial color=3Dblue size=3D1><SPAN=20
  <P class=3DMsoNormal><FONT face=3DArial color=3Dblue size=3D2><SPAN=20
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial">The =
compiler did not=20
  like the =96L or the =96<SPAN class=3DSpellE>lclntsh</SPAN> switches =
under=20
  ORACLESPATIAL_LIB=85So instead I referenced the 3 lib files found in =
the lib=20
  directory.<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: =
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial">Anyway, I =
still do=20
  not get ORACLESPATIAL listed as an =
input=85..<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial">Here is =
what I do=20
  get:<o:p></o:p></SPAN></FONT></P>
Arial">C:\projects\mapserver>mapserv=20
  -v<o:p></o:p></SPAN></FONT></P>
  <P class=3DMsoNormal><SPAN class=3DSpellE><FONT face=3DArial =
Arial">MapServer</SPAN></FONT></SPAN><FONT=20
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial"> version =
4.0=20
  (development) OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP OUTPUT=3DPDF =
OUTPUT=3DSWF=20
  SUPPORTS=3DPROJ SUPPORTS=3DFREE<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial">TYPE=20
  SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER=20
  SUPPORTS=3DWFS_CLIENT INPUT=3DOGR INPUT=3DGDAL=20
  INPUT=3DSHAPEFILE<o:p></o:p></SPAN></FONT></P>
  style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Any other=20
  suggestions?</SPAN></FONT></SPAN><FONT face=3DArial color=3Dnavy =
size=3D2><SPAN=20
Arial"><o:p></o:p></SPAN></FONT></P>
Arial">Cheers,<o:p></o:p></SPAN></FONT></P>
Arial">Richard<o:p></o:p></SPAN></FONT></P>
Arial"><o:p> </o:p></SPAN></FONT></P></DIV></BLOCKQUOTE></BODY></HTM=
L>
------=_NextPart_000_013B_01C3195B.084D2E20--
More information about the MapServer-users
