[Mapserver-users] installing php mapscript without root
poff at sixbit.org
poff at sixbit.org
Tue May 13 13:36:24 EDT 2003
I use a public access unix system, so I can't install php mpscript
globally myself.
I have succesfully compiled the extension, and can run with the dl()
option, however:
Warning: Unable to load dynamic library './php_mapscript.so' - Shared
object "libgd.so.2" not found in /www/path/test.php on line 3
the lib is in the . directory, as well as in the
SetEnv LD_LIBRARY_PATH /path/lib
In .htaccess
Is there any workaround to this without geting libgd globally installed
(which won't happen) ?
Thanks in advance,
poff at sixbit.org
SDF Public Access UNIX System - http://sdf.lonestar.org
