[Mapserver-users] SDE-problem
Jörn Witte
jwitte at gmx.at
Tue May 13 14:00:06 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0006_01C3198A.406B7030
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
=20
I=92ve compiled the Mapserver 3.6.5 on WinXP with MSVC++ 6.0 and
SDE-support successfully.
But if I try to connect the ArcSDE Database, I get the following
error-message:
=20
msSDELayerOpen(): SDE error. SE_connection_create(): Entry for SDE
instance not found in services file. (-102)
=20
The error-message doesn`t exist, if the MapServer and the
ArcSDE-geodatabase are running on the same host.
Does anyone have an idea of what is going wrong?
=20
=20
Thanks,
J=F6rn Witte
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3198A.400CAE60">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
pre
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";
span.EmailFormatvorlage18
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 70.85pt 2.0cm 70.85pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DDE link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-GB =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'><o:p> </o:p></span=
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>I’ve compiled =
the
Mapserver 3.6.5 on WinXP with MSVC++ 6.0 and SDE-support =
successfully.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>But if I try to =
connect the
ArcSDE Database, I get the following =
error-message:<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>msSDELayerOpen(): SDE =
error.
SE_connection_create(): Entry for SDE instance not found in services =
file.
(-102)<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>The error-message =
doesn`t
exist, if the MapServer and the ArcSDE-geodatabase are running on the =
same
host.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Does anyone have an =
idea of
what is going wrong?<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Thanks,<o:p></o:p></spa=
n></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>J=F6rn =
Witte<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
</div>
</body>
</html>
------=_NextPart_000_0006_01C3198A.406B7030--
