[Mapserver-users] Mapserve
Alfred L. Stone
alstone at maine.rr.com
Sat May 3 08:38:31 EDT 2003
I am running freebsd 4.8 I have these libs installed but they aren't
found. Can anyone help?
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... no
libjpeg not found. JPEG support not included, possibly needed
for GD.
checking which version of GD to use...
using libgd from system libs.
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... no
checking for TT_Init_FreeType in -lttf... no
freetype-config or libfreetype cannot be found, possibly needed
for GD
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... no
PNG (libpng) library cannot be found, possibly needed for GD
checking for gdImageCreate in -lgd... no
configure: error: GD is required but was not found... use --with-gd=DIR
to specify its location.
/usr/local/lib/libfreetype.a
/usr/local/lib/libfreetype.so
/usr/local/lib/libfreetype.so.9
/usr/local/include/libpng
/usr/local/include/libpng/png.h
/usr/local/include/libpng/pngconf.h
/usr/local/lib/libpng.a
/usr/local/lib/libpng.so
/usr/local/lib/libpng.so.5
/usr/local/include/gd
/usr/local/include/gd/gd.h
/usr/local/include/gd/gd_io.h
/usr/local/include/gd/gdcache.h
/usr/local/include/gd/gdfontg.h
/usr/local/include/gd/gdfontl.h
/usr/local/include/gd/gdfontmb.h
/usr/local/include/gd/gdfonts.h
/usr/local/include/gd/gdfontt.h
/usr/local/include/gd.h
/usr/local/include/gd_io.h
/usr/local/include/gdcache.h
/usr/local/include/gdfontg.h
/usr/local/include/gdfontl.h
/usr/local/include/gdfontmb.h
/usr/local/include/gdfonts.h
/usr/local/include/gdfontt.h
/usr/local/include/glib-2.0/glib/gdataset.h
/usr/local/include/glib-2.0/glib/gdate.h
/usr/local/include/glib-2.0/glib/gdir.h
/usr/local/include/libwmf/gd
/usr/local/include/libwmf/gd/gd.h
/usr/local/include/libwmf/gd/gd_clip.h
/usr/local/include/libwmf/gd/gd_io.h
/usr/local/include/libwmf/gd/gdcache.h
/usr/local/include/libwmf/gd/gdfontg.h
/usr/local/include/libwmf/gd/gdfontl.h
/usr/local/include/libwmf/gd/gdfontmb.h
/usr/local/include/libwmf/gd/gdfonts.h
/usr/local/include/libwmf/gd/gdfontt.h
/usr/local/include/libwmf/gd.h
/usr/local/lib/libgd.a
/usr/local/lib/libgd.so
/usr/local/lib/libgd.so.2
/usr/local/lib/libgd.so.4
Please Note
The information in this E-mail message is legally privileged
and confidential information intended only for the use of the
individual(s) named above. If you, the reader of this message,
are not the intended recipient, you are hereby notified that
you should not further disseminate, distribute, or forward this
E-mail message. If you have received this E-mail in error,
please notify the sender. Thank you
