[Mapserver-users] Mapserve
Benjamin Thelen CCGIS
benjamin.thelen at ccgis.de
Thu May 15 08:08:41 EDT 2003
Hi Alfred,
I am running mapserver 3.6.5 on FreeBSD 4.7 successfully. I used the
following options.
./configure --with-gd --with-gdal --with-ogr --with-proj=/usr/local --with-j
peg=/us
r/local --with-pdf=/usr/local --with-png=/usr/local --with-zlib --with-freet
ype --w
ith-php=/usr/ports/www/mod_php4/work/php-4.3.1 --with-wmsclient --with-postg
is --en
able-runpat
You have to specify the path for the following options
--with-jpeg=/usr/local
--with-php=/usr/ports/www/mod_php4/work/php-4.3.1
You don't need to specify the following:
--with-gd
--with-gdal
--with-ogr
--with-zlib
--with-freetype
--with-postgis
Don't forget:
--enable-runpat
That should work.
Don't forget the changes in the mapscript Makefile, if you need mapscript!
Benjamin
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Alfred L.
> Stone
> Sent: Saturday, May 03, 2003 2:39 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Mapserve
> I am running freebsd 4.8 I have these libs installed but they aren't
> found. Can anyone help?
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... no
> libjpeg not found. JPEG support not included, possibly needed
> for GD.
> checking which version of GD to use...
> using libgd from system libs.
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... no
> checking for TT_Init_FreeType in -lttf... no
> freetype-config or libfreetype cannot be found, possibly needed
> for GD
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... no
> PNG (libpng) library cannot be found, possibly needed for GD
> checking for gdImageCreate in -lgd... no
> configure: error: GD is required but was not found... use --with-gd=DIR
> to specify its location.
> /usr/local/lib/libfreetype.a
> /usr/local/lib/libfreetype.so
> /usr/local/lib/libfreetype.so.9
> /usr/local/include/libpng
> /usr/local/include/libpng/png.h
> /usr/local/include/libpng/pngconf.h
> /usr/local/lib/libpng.a
> /usr/local/lib/libpng.so
> /usr/local/lib/libpng.so.5
> /usr/local/include/gd
> /usr/local/include/gd/gd.h
> /usr/local/include/gd/gd_io.h
> /usr/local/include/gd/gdcache.h
> /usr/local/include/gd/gdfontg.h
> /usr/local/include/gd/gdfontl.h
> /usr/local/include/gd/gdfontmb.h
> /usr/local/include/gd/gdfonts.h
> /usr/local/include/gd/gdfontt.h
> /usr/local/include/gd.h
> /usr/local/include/gd_io.h
> /usr/local/include/gdcache.h
> /usr/local/include/gdfontg.h
> /usr/local/include/gdfontl.h
> /usr/local/include/gdfontmb.h
> /usr/local/include/gdfonts.h
> /usr/local/include/gdfontt.h
> /usr/local/include/glib-2.0/glib/gdataset.h
> /usr/local/include/glib-2.0/glib/gdate.h
> /usr/local/include/glib-2.0/glib/gdir.h
> /usr/local/include/libwmf/gd
> /usr/local/include/libwmf/gd/gd.h
> /usr/local/include/libwmf/gd/gd_clip.h
> /usr/local/include/libwmf/gd/gd_io.h
> /usr/local/include/libwmf/gd/gdcache.h
> /usr/local/include/libwmf/gd/gdfontg.h
> /usr/local/include/libwmf/gd/gdfontl.h
> /usr/local/include/libwmf/gd/gdfontmb.h
> /usr/local/include/libwmf/gd/gdfonts.h
> /usr/local/include/libwmf/gd/gdfontt.h
> /usr/local/include/libwmf/gd.h
> /usr/local/lib/libgd.a
> /usr/local/lib/libgd.so
> /usr/local/lib/libgd.so.2
> /usr/local/lib/libgd.so.4
> Please Note
> The information in this E-mail message is legally privileged
> and confidential information intended only for the use of the
> individual(s) named above. If you, the reader of this message,
> are not the intended recipient, you are hereby notified that
> you should not further disseminate, distribute, or forward this
> E-mail message. If you have received this E-mail in error,
> please notify the sender. Thank you
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
