[Mapserver-users] installing sde support under linux
Rainer Spittel
rasp at tzi.de
Tue May 6 11:35:27 EDT 2003
Hi all,
I am confused.
I am trying to install a Mapserver for two weeks and got lot of
problems. I solved nearly all of them, except the connection to the
arcSDE gateway. I am using Linux SUSE 8.0, Mapserver V3.6.5, Apache
1.3.27, and PHP 4.2.3. The ArcSDE gateway is running on a different
computer (MS-Win2000). The Mapserver can get access to ESRI Shapefiles
and a local PostGIS database. Now I have some problems to compile the
the mapserver with ArcSDE support. I use the following configuration
file parameters:
./configure --with-proj --with-ogr --with-gdal
--with-postgis=/usr/local/pgsql/bin/pg_config --with-wmsclient
--with-tiff --with-jpeg --with-php=/downloads/services/php-4.2.3
--with-freetype=/usr/include/freetype2 --with-sde --with-sde-version=8.1
My Mapserver currently provide following formats:
MapScript Version ($Revision: 1.104.2.8 $ $Date: 2003/03/05 03:36:53 $)
MapServer version 3.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
My questions are:
- where do I get these ESRI client libraries? I have the ArcSDE V8.1
here and doesn't find them on the CD. :-(
- what else do I have to do to get access to the SDE?
