[Mapserver-users] SDE-support-problem
Steve Lime
steve.lime at dnr.state.mn.us
Wed May 14 15:27:11 EDT 2003
MapLab uses PHP/MapScript, not mapserv.exe. Was that recompiled as well?
>>> Jörn Witte <jwitte at gmx.at> 05/06/03 08:29AM >>>
I've got a question concerning ArcSDE 8.1 and Mapserver 3.6.5.
I've compiled the Mapserver on XP with MSVC++ successfully..
After this, i have move the mapserv.exe into the cgi-bin-folder (Apache)
and
configured a new map-file on MapLab.
Now, i starts the MapBrowser and gets the following message: 'MapServer
Error in msSDELayerOpen(): SDE support is not available.'
Does anyone have an idea of what is going wrong?
Thanks,
Jörn Witte
My configuration is:
C:\Programme\Apache Group\Apache2\cgi-bin>mapserv -v
MapServer version 3.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=SDE
INPUT=OGR INPUT=SHAPEFILE
My Makefile is:
# makefile.vc - Main MapServer makefile for MSVC++
# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the
other
# MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment
variables
# - Start the build with: nmake /f makefile.vc
# $Id: Makefile.vc,v 1.21.2.1 2002/08/01 14:46:45 assefa Exp $
OPTFLAGS = /nologo /Zi /W3 /DDEBUG /DWIN32
#OPTFLAGS = /nologo /Zi
BASE_CFLAGS = $(OPTFLAGS)
LDFLAGS = /NODEFAULTLIB:libcd /DEBUG
CC= cl
LINK= link /debug
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
IGNORE_MISSING_DATA=-DIGNORE_MISSING_DATA
# Apparently these aren't as commonplace as I'd hoped. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
# Proj.4 distribution (cartographic projection routines). Not required
for normal use. (EXPERIMENTAL)
PROJ_LIB=../proj-4.4.3/src/proj.lib
PROJ_INC=-I../proj-4.4.3/src
PROJ=-DUSE_PROJ -DUSE_PROJ_API_H
#Use this flag to compile with WMS support
WMS=-DUSE_WMS
#Use this flag to compile with WMS Client support
#you need the libwww from http://www.w3.org/Library/.
#WMSCLIENT= -DUSE_WMS_LYR
#WWWLIB_INC=-I../libwww/library/src -I../libwww/modules/expat/xmlparse
#WWWLIB_LIB=../libwww/bin/wwwcore.lib ../libwww/bin/wwwapp.lib
../libwww/bin/wwwinit.lib ../libwww/bin/wwwutils.lib
# GD distribution (graphics library GIF and/or PNG support). (REQUIRED)
# - Version 1.2 is included and writes LZW GIF (-DUSE_GD_GIF
-DUSE_GD_SWAP_XY).
# - Versions 1.3 to 1.5 write non-LZW GIF (-DUSE_GD_GIF).
# - Versions 1.6 and greater write PNG (-DUSE_GD_PNG). Add -lpng -lz
to GD_LIB line.
# - Versions 1.8 (or was it 1.7?) also supports JPEG and WBMP
(-DUSE_GD_JPEG -DUSE_GD_WBMP)
# The following lines will compile GD 1.2:
#GDFONT_OBJ= gd-1.2/gdfontt.obj gd-1.2/gdfonts.obj
gd-1.2/gdfontmb.obj \
# gd-1.2/gdfontl.obj gd-1.2/gdfontg.obj
#GD_INC= -I./gd-1.2
#GD_LIB= gd-1.2/gd.lib
#GD= -DUSE_GD_GIF -DUSE_GD_SWAP_XY
#MAKE_GD=gd
# A patched version of GD that supports GIF, JPEG, PNG and WBMP can be
# downloaded from http://www.rime.com.au/gd/.
# The following defns will include the patched GD 1.8.4 with TTF:
GDFONT_OBJ=
GD_INC= -I../gd-1.8.4
GD_LIB= ../gd-1.8.4/gd.lib \
../jpeg-6b/libjpeg.lib \
../lpng120/projects/msvc/win32/libpng/lib_dbg/libpng.lib \
../zlib/zlib.lib ../freetype-2.1.4/objs/freetype214ST_D.lib
GD= -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_TTF \
-DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR
MAKE_GD=gd
# ../jpeg-6b/libjpeg.lib \
# ../libpng-1.0.8/libpng.lib \
# ../zlib/zlibstat.lib ../freetype/lib/freetype.lib
#GD= -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_TTF \
# -DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR
#MAKE_GD=gd
# TIFF distribution (raster support for TIFF and GEOTIFF
imagery).(RECOMMENDED)
TIFF_INC=-I../tiff-v3.5.5/libtiff
TIFF_LIB=../tiff-v3.5.5/libtiff/libtiff.lib
TIFF=-DUSE_TIFF
# JPEG distribution (raster support for grayscale JPEG images, INPUT
ONLY).
#JPEG_INC=
#JPEG_LIB=-ljpeg
#JPEG=-DUSE_JPEG
# EPPL7 Support (this activates ERDAS as well) Included in the
distribution. Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for
more information. (RECOMMENDED)
#EPPL=-DUSE_EPPL
#EPPL_OBJ=epplib.obj
# OGR Support OGC Simple Feature inspired interface for vector
# formats. See http://gdal.velocet.ca/projects/opengis/
GDAL_DIR= ..\gdal-1.1.8
OGR=-DUSE_OGR
OGR_LIB = $(GDAL_DIR)/gdal.lib
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib
$(GDAL_DIR)/ogr/../port/cpl.lib
OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr
-I$(GDAL_DIR)/ogr/../port -I$(GDAL_DIR)/core
#GDAL=-DUSE_GDAL
# ESRI SDE support.
SDE_OPT=-DUSE_SDE -DWIN32
SDE_INC= -I ../arcsde/include -I ../arcsde/bin
SDE_LIB=../arcsde/lib/sde81.lib ../arcsde/lib/sg81.lib
../arcsde/lib/pe81.lib
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=-DUSE_EGIS
#ERR_OBJ=./errLog/errLog.o
#ERR_INC=-I./errLog
#ERR_LIB=-L./errLog -lerrLog
#IMGGEN_OBJ=./imgSrc/imgLib.o
#IMGGEN_INC=-I./imgSrc
#IMGGEN_LIB=-L./imgSrc -limgGEN
#ECWDIR= C:\ProgFile\ECW_SDK
#ECW_LIB=$(ECWDIR)\lib\NCSEcw.lib $(ECWDIR)\lib\NCSEcwC.lib \
# $(ECWDIR)\lib\NCSUtil.lib
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in
the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
#REGEX_OBJ=..\regex-0.12\regex.obj
#REGEX_INC=-I ..\regex-0.12
# IMPORTANT NOTE ABOUT REGEX FOR PHP_MAPSCRIPT USERS:
# If you want to compile the PHP_MAPSCRIPT module, then you have to make
# MapServer uses the same version of the REGEX library that PHP was
# compiled with:
PHP_REGEX=..\php-4.3.1\regex
#PHP_REGEX=..\php-3.0.14\regex
#PHP_REGEX=..\php-4.0.6\regex
#PHP_REGEX=..\php-4.1.2\regex
#PHP_REGEX=..\php-4.2.1\regex
#PHP_REGEX=..\php-4.2.2\regex
REGEX_OBJ=$(PHP_REGEX)\regcomp.obj $(PHP_REGEX)\regerror.obj \
$(PHP_REGEX)\regexec.obj $(PHP_REGEX)\regfree.obj
REGEX_INC=-I$(PHP_REGEX) -DPHP_NO_ALIASES
# REGEX needs some special flags... here they are for VC++ 6.0
#REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
=loaded from http://www.rim
# --- You shouldn't have to edit anything else. ---
# Main MapServer library.
MS_LIB = mapserver.lib
MS_OBJS = mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
mapparser.obj maplexer.obj mapindex.obj maptree.obj \
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
maplegend.obj maputil.obj mapscale.obj mapquery.obj \
maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
mapraster.obj cgiutil.obj mapsde.obj mapogr.obj \
maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj
mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
mapprojhack.obj \
$(EPPL_OBJ) $(REGEX_OBJ)
MS_HDRS = map.h mapfile.h
MS_EXE = mapserv.exe \
shp2img.exe legend.exe \
shptree.exe scalebar.exe sortshp.exe tile4ms.exe
LIBS = $(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(ERR_LIB) $(IMGGEN_LIB) $(OGR_LIB) \
$(WWWLIB_LIB) $(ECW_LIB) $(SDE_LIB)
INCLUDES = $(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(ERR_INC) $(IMGGEN_INC) $(REGEX_INC) $(OGR_INC)
$(WWWLIB_INC) $(SDE_INC)
CFLAGS = $(BASE_CFLAGS) $(INCLUDES) $(REGEX_OPT) $(STRINGS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)
$(WMSCLIENT) \
$(IGNORE_MISSING_DATA) $(GDAL) -DFEATURE_INFO_HTML
$(SDE_OPT)
# $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)
$(WMSCLIENT) \
# $(IGNORE_MISSING_DATA) $(GDAL) -DFEATURE_INFO_HTML
default: all
all: $(MS_LIB) $(MS_EXE)
$(MS_OBJS): $(MS_HDRS)
$(MS_LIB): $(MS_OBJS)
copy $(GDAL_DIR)\gdal11.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
$(MS_EXE): $(LIBS)
gd::
cd gd-1.8.4
nmake /f makefile.nt gd.lib OPTFLAGS="$(OPTFLAGS)"
cd ..
.c.obj:
$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
.cpp.obj:
$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
.c.exe:
$(LINK) $(LDFLAGS) $*.obj $(LIBS)
.cpp.exe:
clean:
del *.obj
del $(REGEX_OBJ)
del $(MS_LIB)
del $(MS_EXE)
del *.pdb
del *.exp
del *.ilk
# cd gd-1.2
# nmake -f makefile.nt clean
# cd ..
my mapfile is:
MAP
NAME "Bremen"
STATUS ON
EXTENT 3.46e+006 5.87198e+006 3.50161e+006 5.90314e+006
SIZE 400 300
IMAGECOLOR 255 255 255
TRANSPARENT OFF
UNITS METERS
INTERLACE ON
IMAGETYPE PNG
IMAGEQUALITY 75
WEB
MINSCALE 20000
MAXSCALE 5e+007
IMAGEPATH "c:/windows/temp/"
IMAGEURL "/ms_tmp/"
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 255 0
STYLE HILITE
END
LEGEND
STATUS OFF
TRANSPARENT FALSE
INTERLACE TRUE
POSITION LL
KEYSIZE 20 10
KEYSPACING 5 5
TEMPLATE "C:/Programme/Apache
Group/Apache2/htdocs/maplab-2.0rc5/htdocs/mapbrowser/legend_template.htm
l"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 255 255 255
PARTIA=loaded from http://www.rimLS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
TRANSPARENT FALSE
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
INTERLACE TRUE
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
LAYER
NAME "Verwaltung"
STATUS ON
DATA "BREMEN_STADTTEILE,shape"
TYPE POLYGON
CONNECTIONTYPE SDE
CONNECTION "kbs2,esri_sde,sde,sde,EsgibtReis"
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
TEMPLATE "ttt.html"
CLASS
NAME "Verwaltungseinheiten"
SYMBOL 0
COLOR 90 200 90
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
