[Mapserver-users] Please Help...Joins with MapServer PHP/Mapscript
Robert Crossley
robert at wotzhere.com
Wed May 14 19:07:17 EDT 2003
Mike,
I had a similar problem with ASP linking to a SQLServer database, and ended
up using the query template to call another page with the (C_LINKCODE) as a
join parameter. Code below - qryaddress is the parameter where the
C_LINKCODE values from the map table is replaced by MapServer, and this is
passed to another .asp page that selects from the other database to display
the results. You need a connection and driver to that database to make it
work, but it is generic to any database. You could redirect it to a php
page just as easily.
Rob.
TEMPLATE PAGE:
<!--Start of Page Body-->
<HTML>
<noscript>
meta-tag "refresh" is provided for those browsers that
do not support JavaScript. Please note that the time
delay is greater than zero.
Notice that this is nested within a "noscript" block.
Which means that browsers that support JavaScript will
not "see" the refresh meta-tag.
<meta http-equiv="refresh" content="1; URL=redirectiontarget.asp">
</noscript>
<BODY>
<SCRIPT LANGUAGE="JavaScript">
<!-- Begin
var now = new Date();
var timestamp = now.getHours()+'.'+now.getMinutes()+'.'+now.getSeconds();
var qryaddress =
"../fmapwebdev/queries/QueryDisplay.asp?PadId=[C_LINKCODE]&QType=Paddock&RF=";
window.location=qryaddress + timestamp
// End -->
</script>
<noscript>
It appears that your browser does not support JavaScript, or you have it
disabled. This site is best viewed with JavaScript enabled.<p>If
JavaScript is disabled in your browser, please turn it back on then reload
this page.<p>Or, if your browser does not support JavaScript, click <a
href="http://xxxxx/fmapweb/queries/QueryDisplay.asp">here</a>.
</noscript>
</HTML>
R
On Wed, 14 May 2003 17:44:17 -0400, Mike Leahy <mgleahy at fes.uwaterloo.ca>
wrote:
> I´m pretty sure I sent a request for info on this question on monday, but
> so far there has been no response...I apologize if I am unnecessarily
> repeating this request.
> Essentially, I´m trying to link a DBF file to the attributes of a
> shapefile. So far, it seems to work (at least there are no errors when
> the mapfile is displayed through the PHP web interface). However, if I
> query a location on the map from the PHP web interface, I get no results
> for the joined table.
> I tried using results templates, as the documentation suggests, but that
> had no impact. After going through code in the PHP/PHTML scripts, it
> seems to me that there is no function included for handling joins in the
> PHP version. Is this the case? If so, how might I go about building
> such functionality myself. If not, perhaps someone can tell me what I
> have missed.
> Using: MapServer 3.5.6 with MapLab 2, on WinXP running IIS (with all
> updates).
> Thanks,
> Mike
> This mail sent through www.mywaterloo.ca
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Robert Crossley Robert Crossley & Assoc P/L
9 Short St
New Brighton 2483
Far Southern Queensland
AUSTRALIA
P: 02 6680 1309
F: New Connection
M: 0419 718 642
E: robert at wotzhere.com
