[Mapserver-users] Please Help...Joins with MapServer PHP/Mapscript
Mike Leahy
mgleahy at fes.uwaterloo.ca
Thu May 15 11:16:19 EDT 2003
Many thanks for the replies.
I've used MapEdit to create the mapfile (below), and GMapFactory to
produce the PHP viewer I've been testing. I've joined a single DBF file
to one of the layers in the mapfile (as you can see below). Both in the
MapEdit preview, and the output from GMapFactory, there is no evidence
of the join. I've tried using various combinations of simple templates
(currently just results.html and testjoin.html - also below). No matter
what I do with the templates, or where I put them (i.e. in the web,
layer, class or join objects), I see no change in the query results
either in the MapEdit preview or the GMapFactory output viewer. They
always just list the attributes for the selected features.
I will also try the maplab-users list...however, I will eventually be
creating a very specific interface to perform analysis using various
linked tables. Perhaps someone can give me some tips or refer me to
some documentation that can help get started building my own web
interface that directly uses MapServer from scratch (using ASP for
example) as opposed to working with the GMapFactory output. This may be
a much better approach for me if I am to try to use MapServer 3.7 when
it is released.
Thanks,
Mike
P.S. yes, I am using MapServer 3.6.5.
------------mapfile---------------
MAP
NAME "Independencia"
STATUS ON
EXTENT 273346 670666 281455 677412
SIZE 600 500
SHAPEPATH "./Independencia"
SYMBOLSET "./Independencia/etc/symbols.sym"
FONTSET "./Independencia/etc/fonts.txt"
IMAGECOLOR 255 255 255
TRANSPARENT FALSE
UNITS METERS
INTERLACE TRUE
IMAGETYPE PNG
IMAGEQUALITY 100
WEB
IMAGEPATH "c:/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
REFERENCE
STATUS ON
IMAGE "./vista.gif"
SIZE 100 60
EXTENT 272051 670801 282750 677277
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
QUERYMAP
STATUS ON
SIZE -1 -1
COLOR 51 100 255
END
LEGEND
STATUS ON
OUTLINECOLOR 0 0 0
IMAGECOLOR 204 204 255
TRANSPARENT FALSE
INTERLACE TRUE
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE "c:/msapps/htdocs/mapedit/legend_template.html"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 0 0 0
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 204 204 204
TRANSPARENT FALSE
UNITS KILOMETERS
INTERVALS 5
SIZE 300 8
STYLE 0
POSITION LL
INTERLACE TRUE
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
LAYER
NAME "Manzanas - Cono"
GROUP "Cono"
STATUS ON
DATA "./manzanas-cono.shp"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
TEMPLATE "ttt.html"
CLASS
NAME "Mananas - Cono"
SYMBOL 0
COLOR 255 255 255
OUTLINECOLOR 204 204 51
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
LAYER
NAME "Escuelas Primarias - Independencia"
GROUP "Independencia"
STATUS ON
DATA "./primary_schools"
TYPE POINT
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TEMPLATE "../Independencia/etc/results.html"
METADATA
"fecha" "2000"
"origen" "Ministerio de Educacíon"
END
CLASS
NAME "Escuelas"
SYMBOL 2
COLOR 150 0 0
SIZE 8
MINSIZE 1
MAXSIZE 100
TEMPLATE "./Independencia/etc/results.html"
JOIN
NAME "testjoin"
TYPE SINGLE
TABLE "./Independencia/blocks.dbf"
FROM "Cod_mod"
TO "Cod_mod"
TEMPLATE "./Independencia/etc/testjoin.html"
END
END
END
LAYER
NAME "Sectores - Independencia"
STATUS ON
DATA "./sectores"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
LABELITEM "Red_nom"
TOLERANCE 3
TEMPLATE "ttt.html"
CLASS
NAME "Sectores"
SYMBOL 0
OUTLINECOLOR 102 0 0
SIZE 3
MINSIZE 1
MAXSIZE 100
LABEL
TYPE TRUETYPE
FONT "Arial-Bold"
SIZE 10
MINSIZE 10
MAXSIZE 10
POSITION CC
OFFSET 0 0
ANGLE 0.000000
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 204
ANTIALIAS TRUE
PARTIALS TRUE
FORCE FALSE
END
END
END
END
--------results.html--------------
<html>
<body>
[testjoin]
</body>
<html>
--------testjoin.html-------------
<br>[MANZID]
_________________________________________________________________
-----Original Message-----
Sent: May 14, 2003 8:24 PM
To: Maplab-users
Cc: Mike Leahy
Subject: Re: [Mapserver-users] Please Help...Joins with MapServer
PHP/Mapscript
Did you mean MapServer 3.6.5? In any case, there is a problem with
queries in MapLab 2 that we have not had time to research.
I don't know exactly how you are attempting to link the DBF file,
perhaps you could provide some details on this.
Also, where are you not getting query results (MapEdit preview,
MapBrowser, or GMapFactory)?
When the 3.7 branch is released as stable, there is new functionality
through OGR to link shape files directly to DBF files that was added by
Frank Warmerdam. It works like a charm, but unfortunately MapLab has
not yet been updated for the 3.7 branch (look for it around 30 May).
Finally, since this is a maplab-specific question, you would have more
luck with it on the maplab-users list.
Cheers,
Paul
Mike Leahy wrote:
> I´m pretty sure I sent a request for info on this question on monday,
but so
> far there has been no response...I apologize if I am unnecessarily
repeating
> this request.
> Essentially, I´m trying to link a DBF file to the attributes of a
shapefile.
> So far, it seems to work (at least there are no errors when the
mapfile is
> displayed through the PHP web interface). However, if I query a
location on
> the map from the PHP web interface, I get no results for the joined
table.
> I tried using results templates, as the documentation suggests, but
that had no
> impact. After going through code in the PHP/PHTML scripts, it seems
to me that
> there is no function included for handling joins in the PHP version.
Is this
> the case? If so, how might I go about building such functionality
myself. If
> not, perhaps someone can tell me what I have missed.
> Using: MapServer 3.5.6 with MapLab 2, on WinXP running IIS (with all
updates).
> Thanks,
> Mike
> This mail sent through www.mywaterloo.ca
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
