[Mapserver-users] Problems with querybypoint/phpmapscript
Charlton Purvis
cpurvis at asg.sc.edu
Thu May 15 09:24:11 EDT 2003
Could you forward your .map and code to the list? What MS version are
you using?
-----Original Message-----
From: Andreas Hirner [mailto:andreas_hirner at hotmail.com]
Sent: Thursday, May 15, 2003 5:01 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Problems with querybypoint/phpmapscript
Hello List,
I wrote a function using querybypoint()/querybyrect() that queries shape
files. This function works well on all the layers of the Itasca demo
data
set. Now I tried to get it working with another data set, but the query
does
not return any results. However:
The layer does have a template and a class section in the map file.
The layer can be queried using Esri's Arc Explorer.
The layer also renders correctly according to the instructions in the
map
file.
What am I missing?
Thanks
Andreas Hirner
_________________________________________________________________
Protect your PC - get McAfee.com VirusScan Online
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
