[Mapserver-users] Problems with querybypoint/phpmapscript
Andreas Hirner
andreas_hirner at hotmail.com
Fri May 16 05:22:18 EDT 2003
Hello List,
>Could you forward your .map and code to the list? What MS version are
>you using?
Here is the layer definition in the map file:
LAYER
NAME "tknetz"
DATA "tknetz"
TYPE POLYGON
STATUS OFF
TEMPLATE "dummy.html"
CLASS
NAME "Netz"
OUTLINECOLOR 0 0 0
END
TOLERANCE 5
END # tknetz
And this is the php script:
$extent = ms_newRectObj();
$extent->setextent($this->extentCurrent[0],$this->extentCurrent[1],$this->extentCurrent[2],$this->extentCurrent[3]);
$this->map->queryByRect($extent);
The extentCurrent[] array contains the correct values. The error message
always states that the query did not return any results.
>-----Original Message-----
>From: Andreas Hirner [mailto:andreas_hirner at hotmail.com]
>Sent: Thursday, May 15, 2003 5:01 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] Problems with querybypoint/phpmapscript
>Hello List,
>I wrote a function using querybypoint()/querybyrect() that queries shape
>files. This function works well on all the layers of the Itasca demo
>data
>set. Now I tried to get it working with another data set, but the query
>does
>not return any results. However:
>The layer does have a template and a class section in the map file.
>The layer can be queried using Esri's Arc Explorer.
>The layer also renders correctly according to the instructions in the
>map
>file.
>What am I missing?
>Thanks
>Andreas Hirner
>_________________________________________________________________
>Protect your PC - get McAfee.com VirusScan Online
>http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Tired of spam? Get advanced junk mail protection with MSN 8.
http://join.msn.com/?page=features/junkmail
