[Mapserver-users] Problems with querybypoint/phpmapscript
Andreas Hirner
andreas_hirner at hotmail.com
Mon May 19 05:48:03 EDT 2003
Hello,
I am afraid if my question did not contain enough information. I was under
the impression that the previous mailings appended to this one contained
all the necessary details.
However I was able to solve the problem on my own. The answer is quite
simple: The status of the layer has to be set to "on" in order for
queryByPoint()/queryByRect() to obtain any results.
Thanks
Andreas
>Hi
>You need to send more information if you expect a good
>answer. A well thought out question gives a well thought
>out answer on this list.
>Cheers
>--- Andreas Hirner <andreas_hirner at hotmail.com> wrote:
> > Hello List,
> > >Could you forward your .map and code to the list? What
> > MS version are
> > >you using?
> > Here is the layer definition in the map file:
> > LAYER
> > NAME "tknetz"
> > DATA "tknetz"
> > TYPE POLYGON
> > STATUS OFF
> > TEMPLATE "dummy.html"
> > CLASS
> > NAME "Netz"
> > OUTLINECOLOR 0 0 0
> > END
> > TOLERANCE 5
> > END # tknetz
> > And this is the php script:
> > $extent = ms_newRectObj();
>$extent->setextent($this->extentCurrent[0],$this->extentCurrent[1],$this->extentCurrent[2],$this->extentCurrent[3]);
> > $this->map->queryByRect($extent);
> > The extentCurrent[] array contains the correct values.
> > The error message
> > always states that the query did not return any results.
> > >-----Original Message-----
> > >From: Andreas Hirner [mailto:andreas_hirner at hotmail.com]
> > >Sent: Thursday, May 15, 2003 5:01 AM
> > >To: mapserver-users at lists.gis.umn.edu
> > >Subject: [Mapserver-users] Problems with
> > >Hello List,
> > >I wrote a function using querybypoint()/querybyrect()
> > that queries shape
> > >files. This function works well on all the layers of
> > the Itasca demo
> > >data
> > >set. Now I tried to get it working with another data
> > set, but the query
> > >does
> > >not return any results. However:
> > >The layer does have a template and a class section in
> > the map file.
> > >The layer can be queried using Esri's Arc Explorer.
> > >The layer also renders correctly according to the
> > instructions in the
> > >map
> > >file.
> > >What am I missing?
> > >Thanks
> > >Andreas Hirner
> >_________________________________________________________________
> > >Protect your PC - get McAfee.com VirusScan Online
> >http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > >Mapserver-users mailing list
> > >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Tired of spam? Get advanced junk mail protection with MSN
> > 8.
> > http://join.msn.com/?page=features/junkmail
>Do you Yahoo!?
>The New Yahoo! Search - Faster. Easier. Bingo.
>http://search.yahoo.com
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
