[Mapserver-users] demo installation
Louis Paladino
loupaladino at yahoo.com
Thu May 15 18:39:34 EDT 2003
--0-1101040454-1053038374=:19783
Content-Type: text/plain; charset=us-ascii
MapServer users,
MapServer: ms363gif_gdal_wms
demo: itasca3.5
web server: Apache 2.0.45
OS: Win2k
I am a student and just began to work with Mapserver. I am hoping receive help on the demo installation please.
My problem is as follows: When I go to test the demo installation as advised by typing in my URL, and click initialize, the MapServer Demo Interface appears. However, my image window is all black, no maps. I think it is something little; such as not correctly defining in the map or demo_init file where my maps sit. But after playing around I cannot find the solution.
I have added those two files into the e-mail. Thanks in advance!!
DEMO_INIT
<html>
<head><title>MapServer Demo Interface</title></head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Demo Interface</h2></center>
<p><hr><p>
Click on the initialize button to fire up the demo with 3 layers turned on will be accessible for browsing. The
data are of Itasca County, MN and were derived, for the most part, from USGS 1:24,000 quadrangles. Some things to note are:
<form method=GET action="/cgi-bin/mapserv.exe">
<input type="hidden" name="map" value="C:\Apache\Apache2\htdocs\itasca\demo.map">
<input type="hidden" name="layer" value="lakespy2">
<input type="hidden" name="layer" value="dlgstln2">
<input type="hidden" name="zoomsize" value=2>
<input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
<input type="hidden" name="map_web_imagepath" value="C:\Apache\Apache2\htdocs\tmp">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
<center><input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
</body></html>
MAP FILE
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://emarcano2/itasca/demo_init.html"
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME ctybdpy2
TYPE POLYGON
STATUS DEFAULT
DATA ctybdpy2
CLASSITEM 'cty_name'
CLASS
EXPRESSION 'Itasca'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS # every other county in the state
EXPRESSION /./
COLOR 255 255 255
END
METADATA
WMS_TITLE "County Boundary"
WMS_ABSTRACT "Itasca County boundary shapefile. See http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more information."
END
END
etc..
etc..
etc..
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
Content-Type: text/html; charset=us-ascii
<DIV>
<DIV>
<DIV>MapServer users,</DIV>
<DIV> </DIV>
<DIV>MapServer: ms363gif_gdal_wms</DIV>
<DIV>demo: itasca3.5</DIV>
<DIV>web server: Apache 2.0.45 </DIV>
<DIV>OS: Win2k</DIV>
<DIV> </DIV>
<DIV>I am a student and just began to work with Mapserver. I am hoping receive help on the demo installation please. </DIV>
<DIV> </DIV>
<DIV>My problem is as follows: When I go to test the demo installation as advised by typing in my URL, and click initialize, the MapServer Demo Interface appears. However, my image window is all black, no maps. I think it is something little; such as not correctly defining in the map or demo_init file where my maps sit. But after playing around I cannot find the solution.</DIV>
<DIV> </DIV>
<DIV>I have added those two files into the e-mail. Thanks in advance!!</DIV>
<DIV> </DIV>
<DIV><U>DEMO_INIT</U></DIV>
<DIV><html><BR><head><title>MapServer Demo Interface</title></head><BR><body bgcolor="#FFFFFF"></DIV>
<DIV><center><h2>MapServer Demo Interface</h2></center><BR><p><hr><p><BR>Click on the initialize button to fire up the demo with 3 layers turned on will be accessible for browsing. The<BR>data are of Itasca County, MN and were derived, for the most part, from USGS 1:24,000 quadrangles. Some things to note are:</DIV>
<DIV><form method=GET action="/cgi-bin/mapserv.exe"></DIV>
<DIV><input type="hidden" name="map" value="C:\Apache\Apache2\htdocs\itasca\demo.map"><BR><input type="hidden" name="layer" value="lakespy2"><BR><input type="hidden" name="layer" value="dlgstln2"><BR><input type="hidden" name="zoomsize" value=2></DIV>
<DIV><input type="hidden" name="program" value="/cgi-bin/mapserv.exe"><BR><input type="hidden" name="map_web_imagepath" value="C:\Apache\Apache2\htdocs\tmp"><BR><input type="hidden" name="map_web_imageurl" value="/tmp/"></DIV>
<DIV><center><input type="submit" value="Initialize"></center></DIV>
<DIV></form></DIV>
<DIV><p><hr><p></DIV>
<DIV></body></html></DIV>
<DIV><U>MAP FILE</U></DIV>
<DIV>#<BR># Start of map file<BR>#<BR>NAME DEMO<BR>STATUS ON<BR>SIZE 600 600<BR>EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897<BR>UNITS METERS<BR>SHAPEPATH "data"<BR>IMAGECOLOR 255 255 255</DIV>
<DIV># you may need to change this to match your MapServer build<BR>#IMAGETYPE PNG</DIV>
<DIV>#<BR># Projection definition, consult the PROJ.4 documentation for parameter discussion<BR>#<BR>#PROJECTION<BR># "proj=utm"<BR># "ellps=GRS80"<BR># "zone=15"<BR># "north"<BR># "no_defs"<BR>#<BR># OR: <BR>#<BR># "init=epsg:26915"<BR>#END</DIV>
<DIV>#<BR># Start of web interface definition (including WMS enabling metadata)<BR>#<BR>WEB<BR> HEADER demo_header.html<BR> TEMPLATE demo.html<BR> FOOTER demo_footer.html<BR> MINSCALE 1000<BR> MAXSCALE 1550000<BR> IMAGEPATH "set in demo_init.html"<BR> IMAGEURL "set in demo_init.html"<BR> METADATA<BR> WMS_TITLE "UMN MapServer Itasca Demo"<BR> WMS_ABSTRACT "This is the UMN MapServer demonstration application for Itasca County located in north central Minnesota."<BR> WMS_ACCESSCONSTRAINTS none</DIV>
<DIV> # change this value to match your setup<BR> WMS_ONLINERESOURCE "<A href="http://emarcano2/itasca/demo_init.html">http://emarcano2/itasca/demo_init.html</A>"</DIV>
<DIV> WMS_SRS "EPSG:26915"<BR> END<BR>END</DIV>
<DIV>QUERYMAP<BR> SIZE 200 200<BR> STATUS ON<BR> STYLE HILITE<BR> COLOR 255 0 0<BR>END</DIV>
<DIV>#<BR># Start of reference map<BR>#<BR>REFERENCE<BR> IMAGE graphics/reference.gif<BR> EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127<BR> SIZE 120 120<BR> STATUS ON<BR> COLOR -1 -1 -1<BR> OUTLINECOLOR 255 0 0<BR>END</DIV>
<DIV>#<BR># Start of legend<BR>#<BR>LEGEND<BR> KEYSIZE 18 12<BR> LABEL<BR> TYPE BITMAP<BR> SIZE MEDIUM<BR> COLOR 0 0 89<BR> END<BR> STATUS ON<BR>END</DIV>
<DIV>#<BR># Start of scalebar<BR>#<BR>SCALEBAR<BR> IMAGECOLOR 255 255 255<BR> LABEL<BR> COLOR 255 255 255<BR> SIZE tiny <BR> END<BR> STYLE 1<BR> SIZE 80 2<BR> COLOR 255 255 255<BR> UNITS MILES<BR> INTERVALS 1<BR> TRANSPARENT TRUE<BR> STATUS TRUE<BR>END</DIV>
<DIV>#<BR># Start of symbol definitions (we're only using a few)<BR>#<BR>SYMBOL<BR> NAME 'circle'<BR> TYPE ELLIPSE<BR> POINTS 1 1 END<BR> FILLED TRUE<BR>END</DIV>
<DIV>#<BR># Start of layer definitions<BR>#</DIV>
<DIV>LAYER<BR> NAME ctybdpy2<BR> TYPE POLYGON<BR> STATUS DEFAULT<BR> DATA ctybdpy2<BR> <BR> CLASSITEM 'cty_name'<BR> CLASS<BR> EXPRESSION 'Itasca'<BR> OUTLINECOLOR 128 128 128<BR> COLOR 225 225 185<BR> END<BR> CLASS # every other county in the state<BR> EXPRESSION /./ <BR> OUTLINECOLOR 128 128 128<BR> COLOR 255 255 255<BR> END<BR> METADATA<BR> WMS_TITLE "County Boundary"<BR> WMS_ABSTRACT "Itasca County boundary shapefile. See <A href="http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html">http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html</A> for more information."<BR> WMS_SRS "EPSG:26915"<BR> END<BR>END<BR>etc..</DIV>
<DIV>etc..</DIV>
<DIV>etc..</DIV></DIV></DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://us.rd.yahoo.com/search/mailsig/*http://search.yahoo.com">The New Yahoo! Search</a> - Faster. Easier. Bingo.
--0-1101040454-1053038374=:19783--
