[Mapserver-users] demo installation
Ed McNierney
ed at topozone.com
Thu May 15 19:14:22 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C31B37.B82AD9A0
Content-Type: text/plain;
charset="US-ASCII"
Content-Transfer-Encoding: quoted-printable
Louis -
=20
Those "etc. etc."s at the end make a difference! You're turning on two
layers named "lakespy2" and "dlgstln2" - are those in your MAP file?
=20
Your setup looks generally good. Getting a black map (not a BLANK map,
but one that's solid black) usually means that everything's working fine
but the particular request you made doesn't display any data. This is
usually caused by either (a) requesting EXTENTs that do not overlap the
visible data or (b) not turning on any layers or both.
=20
- Ed
=20
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
=20
-----Original Message-----
From: Louis Paladino [mailto:loupaladino at yahoo.com]=20
Sent: Thursday, May 15, 2003 6:40 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] demo installation
=20
MapServer users,
=20
MapServer: ms363gif_gdal_wms
demo: itasca3.5
web server: Apache 2.0.45=20
OS: Win2k
=20
I am a student and just began to work with Mapserver. I am hoping
receive help on the demo installation please. =20
=20
My problem is as follows: When I go to test the demo installation as
advised by typing in my URL, and click initialize, the MapServer Demo
Interface appears. However, my image window is all black, no maps. I
think it is something little; such as not correctly defining in the map
or demo_init file where my maps sit. But after playing around I cannot
find the solution.
=20
I have added those two files into the e-mail. Thanks in advance!!
=20
DEMO_INIT
<html>
<head><title>MapServer Demo Interface</title></head>
<body bgcolor=3D"#FFFFFF">
<center><h2>MapServer Demo Interface</h2></center>
<p><hr><p>
Click on the initialize button to fire up the demo with 3 layers turned
on will be accessible for browsing. The
data are of Itasca County, MN and were derived, for the most part, from
USGS 1:24,000 quadrangles. Some things to note are:
<form method=3DGET action=3D"/cgi-bin/mapserv.exe">
<input type=3D"hidden" name=3D"map"
value=3D"C:\Apache\Apache2\htdocs\itasca\demo.map">
<input type=3D"hidden" name=3D"layer" value=3D"lakespy2">
<input type=3D"hidden" name=3D"layer" value=3D"dlgstln2">
<input type=3D"hidden" name=3D"zoomsize" value=3D2>
<input type=3D"hidden" name=3D"program" value=3D"/cgi-bin/mapserv.exe">
<input type=3D"hidden" name=3D"map_web_imagepath"
value=3D"C:\Apache\Apache2\htdocs\tmp">
<input type=3D"hidden" name=3D"map_web_imageurl" value=3D"/tmp/">
<center><input type=3D"submit" value=3D"Initialize"></center>
</form>
<p><hr><p>
</body></html>
MAP FILE
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=3Dutm"
# "ellps=3DGRS80"
# "zone=3D15"
# "north"
# "no_defs"
# OR:=20
# "init=3Depsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application
for Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://emarcano2/itasca/demo_init.html"
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
EXTENT 393234.393701263 5205405.16440722 495769.579718949
5307959.02579127
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny =20
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME ctybdpy2
TYPE POLYGON
STATUS DEFAULT
DATA ctybdpy2
=20
CLASSITEM 'cty_name'
CLASS
EXPRESSION 'Itasca'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS # every other county in the state
EXPRESSION /./=20
COLOR 255 255 255
END
METADATA
WMS_TITLE "County Boundary"
WMS_ABSTRACT "Itasca County boundary shapefile. See
http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
information."
END
END
etc..
etc..
etc..
_____ =20
Do you Yahoo!?
The New Yahoo! Search
<http://us.rd.yahoo.com/search/mailsig/*http:/search.yahoo.com> -
Faster. Easier. Bingo.
Content-Type: text/html;
charset="US-ASCII"
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
p
{margin-right:0in;
margin-left:0in;
font-size:12.0pt;
span.EmailStyle18
{font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dblue>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Louis –</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> </span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Those “etc. etc.”s at =
the end
make a difference! You’re turning on two layers named =
“lakespy2”
and “dlgstln2” – are those in your MAP =
file?</span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Your setup looks generally =
good. Getting
a black map (not a BLANK map, but one that’s solid black) usually =
means
that everything’s working fine but the particular request you made =
doesn’t
display any data. This is usually caused by either (a) requesting =
EXTENTs that
do not overlap the visible data or (b) not turning on any layers or =
both.</span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> =
- Ed</span></font></p>
style=3D'font-size:
<div>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ed McNierney</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>President and Chief =
Mapmaker</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>TopoZone.com / Maps a la carte, =
Inc.</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>73 Princeton Street, Suite =
305</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>North Chelmsford, MA =
01863</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Phone: (978) 251-4242 Fax: =
(978) 251-1396</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>ed at topozone.com</span></font></p>
</div>
style=3D'font-size:
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>-----Original =
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Louis Paladino
[mailto:loupaladino at yahoo.com] <br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> Thursday, May 15, =
2003 6:40
PM<br>
<b><span style=3D'font-weight:bold'>To:</span></b>
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
installation</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 =
face=3D"Times New Roman"><span
style=3D'font-size:12.0pt'> </span></font></p>
<div>
<div>
<div>
style=3D'font-size:12.0pt'>MapServer users,</span></font></p>
</div>
<div>
</div>
<div>
style=3D'font-size:12.0pt'>MapServer: =
ms363gif_gdal_wms</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'>demo: itasca3.5</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'>web server: Apache 2.0.45 </span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'>OS: Win2k</span></font></p>
</div>
<div>
</div>
<div>
style=3D'font-size:12.0pt'>I am a student and just began to work with
Mapserver. I am hoping receive help on the demo installation
please. </span></font></p>
</div>
<div>
</div>
<div>
style=3D'font-size:12.0pt'>My problem is as follows: When I go to test =
the demo
installation as advised by typing in my URL, and click initialize, the
MapServer Demo Interface appears. However, my image window is all =
black,
no maps. I think it is something little; such as not correctly =
defining
in the map or demo_init file where my maps sit. But after playing =
around
I cannot find the solution.</span></font></p>
</div>
<div>
</div>
<div>
style=3D'font-size:12.0pt'>I have added those two files into the =
e-mail.
Thanks in advance!!</span></font></p>
</div>
<div>
</div>
<div>
<p class=3DMsoNormal style=3D'margin-left:.5in'><u><font size=3D3
face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt'>DEMO_INIT</span></font></u></p>
</div>
<div>
style=3D'font-size:12.0pt'><html><br>
<head><title>MapServer Demo =
Interface</title></head><br>
<body bgcolor=3D"#FFFFFF"></span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'><center><h2>MapServer Demo
Interface</h2></center><br>
<p><hr><p><br>
Click on the initialize button to fire up the demo with 3 layers turned =
on will
be accessible for browsing. The<br>
data are of Itasca County, MN and were derived, for the most part, from =
USGS
1:24,000 quadrangles. Some things to note are:</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'><form method=3DGET
action=3D"/cgi-bin/mapserv.exe"></span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'><input type=3D"hidden" =
name=3D"map"
value=3D"C:\Apache\Apache2\htdocs\itasca\demo.map"><br>
value=3D"lakespy2"><br>
value=3D"dlgstln2"><br>
<input type=3D"hidden" name=3D"zoomsize" =
value=3D2></span></font></p>
</div>
<div>
name=3D"program" =
value=3D"/cgi-bin/mapserv.exe"><br>
<input type=3D"hidden" name=3D"map_web_imagepath" =
value=3D"C:\Apache\Apache2\htdocs\tmp"><br>
value=3D"/tmp/"></span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'><center><input =
type=3D"submit"
value=3D"Initialize"></center></span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'></form></span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'><p><hr><p></span></font></p>=
</div>
<div>
style=3D'font-size:12.0pt'></body></html></span></font></p>
</div>
<div>
face=3D"Times New Roman"><span style=3D'font-size:12.0pt'>MAP =
FILE</span></font></u></p>
</div>
<div>
style=3D'font-size:12.0pt'>#<br>
# Start of map file<br>
#<br>
NAME DEMO<br>
STATUS ON<br>
SIZE 600 600<br>
EXTENT 388107.634400379 5203120.88405952 500896.339019834 =
5310243.30613897<br>
UNITS METERS<br>
SHAPEPATH "data"<br>
IMAGECOLOR 255 255 255</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'># you may need to change this to match your =
build<br>
#IMAGETYPE PNG</span></font></p>
</div>
<div>
discussion<br>
#<br>
#PROJECTION<br>
# "proj=3Dutm"<br>
# "ellps=3DGRS80"<br>
# "zone=3D15"<br>
# "north"<br>
# "no_defs"<br>
#<br>
# OR: <br>
#<br>
# "init=3Depsg:26915"<br>
#END</span></font></p>
</div>
<div>
# Start of web interface definition (including WMS enabling =
metadata)<br>
#<br>
WEB<br>
HEADER demo_header.html<br>
TEMPLATE demo.html<br>
FOOTER demo_footer.html<br>
MINSCALE 1000<br>
MAXSCALE 1550000<br>
IMAGEPATH "set in demo_init.html"<br>
IMAGEURL "set in demo_init.html"<br>
METADATA<br>
WMS_TITLE "UMN MapServer Itasca Demo"<br>
WMS_ABSTRACT "This is the UMN MapServer =
demonstration
application for Itasca County located in north central =
Minnesota."<br>
WMS_ACCESSCONSTRAINTS none</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'> # change this value to =
match your
setup<br>
WMS_ONLINERESOURCE "<a
href=3D"http://emarcano2/itasca/demo_init.html">http://emarcano2/itasca/d=
emo_init.html</a>"</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'> WMS_SRS =
"EPSG:26915"<br>
END<br>
</div>
<div>
style=3D'font-size:12.0pt'>QUERYMAP<br>
SIZE 200 200<br>
STATUS ON<br>
STYLE HILITE<br>
COLOR 255 0 0<br>
</div>
<div>
# Start of reference map<br>
#<br>
REFERENCE<br>
IMAGE graphics/reference.gif<br>
EXTENT 393234.393701263 5205405.16440722 495769.579718949 =
5307959.02579127<br>
SIZE 120 120<br>
STATUS ON<br>
COLOR -1 -1 -1<br>
OUTLINECOLOR 255 0 0<br>
</div>
<div>
# Start of legend<br>
#<br>
LEGEND<br>
KEYSIZE 18 12<br>
LABEL<br>
TYPE BITMAP<br>
SIZE MEDIUM<br>
COLOR 0 0 89<br>
END<br>
STATUS ON<br>
</div>
<div>
# Start of scalebar<br>
#<br>
SCALEBAR<br>
IMAGECOLOR 255 255 255<br>
LABEL<br>
SIZE tiny <br>
END<br>
STYLE 1<br>
SIZE 80 2<br>
UNITS MILES<br>
INTERVALS 1<br>
TRANSPARENT TRUE<br>
STATUS TRUE<br>
</div>
<div>
# Start of symbol definitions (we're only using a few)<br>
#<br>
SYMBOL<br>
NAME 'circle'<br>
TYPE ELLIPSE<br>
POINTS 1 1 END<br>
FILLED TRUE<br>
</div>
<div>
# Start of layer definitions<br>
#</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'>LAYER<br>
NAME ctybdpy2<br>
TYPE POLYGON<br>
STATUS DEFAULT<br>
DATA ctybdpy2<br>
<br>
CLASSITEM 'cty_name'<br>
CLASS<br>
EXPRESSION 'Itasca'<br>
OUTLINECOLOR 128 128 128<br>
COLOR 225 225 185<br>
END<br>
CLASS # every other county in the state<br>
EXPRESSION /./ <br>
END<br>
METADATA<br>
WMS_TITLE "County Boundary"<br>
WMS_ABSTRACT "Itasca County boundary shapefile. =
See <a
href=3D"http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html">http://d=
eli.dnr.state.mn.us/metadata/full/ctybdne2.html</a>
for more information."<br>
WMS_SRS "EPSG:26915"<br>
END<br>
END<br>
etc..</span></font></p>
</div>
<div>
style=3D'font-size:12.0pt'>etc..</span></font></p>
</div>
<div>
</div>
</div>
</div>
<div class=3DMsoNormal align=3Dcenter =
style=3D'margin-left:.5in;text-align:center'><font
size=3D3 face=3D"Times New Roman"><span style=3D'font-size:12.0pt'>
<hr size=3D1 width=3D"100%" align=3Dcenter>
</span></font></div>
style=3D'font-size:12.0pt'>Do you Yahoo!?<br>
<a =
href=3D"http://us.rd.yahoo.com/search/mailsig/*http:/search.yahoo.com">Th=
e New
Yahoo! Search</a> - Faster. Easier. Bingo.</span></font></p>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C31B37.B82AD9A0--
