[Mapserver-users] Building gdal with Xerces
Frank Warmerdam
warmerdam at pobox.com
Fri May 16 13:49:35 EDT 2003
Benjamin Thelen (CCGIS) wrote:
> That means 1.7.0 won't run? Do you think, that xerces 1.6.0 would
> automatically be recognized by gdal at installation time of gdal? Otherwise
> I would have to find out what to specify for --with-xerces-in=dir
> and --with-xerces-lib=opts. Especiall the last one is a miracle to me.
> Thanks,
> Ben
Ben,
Xerces should be found automatically if it is in the default locations
(I think). The --with-xerces-lib and --with-xcerces-inc items can be
used to specifically control the include and link directives if necessary.
Generally if you build and install xerces in a non-standard location you
can use --with-xerces=/opt or something similar.
1.7.0 likely will work, and I thought that some 2.x versions were working
after I made a slight improvement to the include logic, but I am a bit
uncertain about this. I am willing to update the GML code to support more
modern Xerces versions if you need. Just file a bug report in Bugzilla.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
