[Mapserver-users] php regex error
Gerald Buckmaster
gbuckmaster at cox.net
Sat May 17 20:44:44 EDT 2003
All Concerned,
I have seen this same problem exposed in the archives, but haven't seen a
solution. First my system:
Mandrake 9.1
php 4.3.1 (source)
mapserver 3.6.5 (source)
My php configure:
./configure --with-system-regex --with-mysql=/usr/local
My mapserver 3.6.5 configure:
./configure --with-jpeg=/usr/local \
--with-png=/usr/local \
--with-proj=/usr/local \
--disable-ignore-missing-data \
--with-php=/usr/local/src/php-4.3.1 \
--with-gdal \
--with-ogr \
--with-postgis=yes \
--disable-rxposix-conflict-error
I get the error during the mapserver 3.6.5 configure process:
checking whether we have PHP3 or PHP4... -DPHP4
checking whether we should use PHP's regex... yes
configure: error:
!!! The current version of PHP MapScript has some problems with !!!
!!! PHP4's bundled regex. Until we figure the solution to the !!!
!!! problem, the workaround is to compile PHP4 with the system regex !!!
!!! Please re-configure and re-compile PHP4 with --with-system-regex !!!
!!! and then re-configure and re-compile MapServer. !!!
How do I stop mapserver build from using the PHP regex? I am using the system
regex during the building of PHP, so why am I still getting this configure
error?
Respectfully,
Gerald Buckmaster
