[Mapserver-users] php regex error
Paul Spencer
spencer at dmsolutions.ca
Sat May 17 22:50:23 EDT 2003
try configuring php with --with-regex=system.
Cheers,
Paul
Gerald Buckmaster wrote:
> All Concerned,
> I have seen this same problem exposed in the archives, but haven't seen a
> solution. First my system:
> Mandrake 9.1
> php 4.3.1 (source)
> mapserver 3.6.5 (source)
> My php configure:
> ./configure --with-system-regex --with-mysql=/usr/local
> My mapserver 3.6.5 configure:
> ./configure --with-jpeg=/usr/local \
> --with-png=/usr/local \
> --with-proj=/usr/local \
> --disable-ignore-missing-data \
> --with-php=/usr/local/src/php-4.3.1 \
> --with-gdal \
> --with-ogr \
> --with-postgis=yes \
> --disable-rxposix-conflict-error
> I get the error during the mapserver 3.6.5 configure process:
> checking whether we have PHP3 or PHP4... -DPHP4
> checking whether we should use PHP's regex... yes
> configure: error:
> !!! The current version of PHP MapScript has some problems with !!!
> !!! PHP4's bundled regex. Until we figure the solution to the !!!
> !!! problem, the workaround is to compile PHP4 with the system regex !!!
> !!! Please re-configure and re-compile PHP4 with --with-system-regex !!!
> !!! and then re-configure and re-compile MapServer. !!!
> How do I stop mapserver build from using the PHP regex? I am using the system
> regex during the building of PHP, so why am I still getting this configure
> error?
> Respectfully,
> Gerald Buckmaster
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
