[Mapserver-users] Optimal Configuration of Apache for PHP/MapScript PostgreSQL PostGIS Mapserver
Gerald Buckmaster
gbuckmaster at cox.net
Sun May 18 14:57:19 EDT 2003
Greetings,
I know the subject has been broached in the past, and opinions will vary, but
I want to learn (and document) how to build a reliable Mapserver on a
Mandrake 9.1 system from scratch, with these caveats: I want to use
PHP/Mapscript with PostgreSQL as the back-end data engine for vector data;
and MapLab as the administration interface. In the future I want to build
interactive web interfaces that will allow creation, archive and display of
vector data by users, as well as "on-the-fly" vector data creation from
serialized feeds. I am a imagery analyst by profession, so I want to utilize
(import, archive, display, rectify, export, etc) a variety of raster data
sources, such as HDF, GeoTIFF, NTF, DEM, DTED, CADRG, and other more or less
obscure satellite sensor and vector data formats.
Looking through all the list archives and configure --help arguments, it
appears I should download and build source code and a fairly unwavering
sequence is required. Please comment on the necessity and build sequence of
the list below (there's probably some missing):
jpeg-6b
shapelib
proj
jasper
libgrass
hdf4.1r5
libtiff
libgeotiff
gd
gdal
postgresql
postgis
php
apache
mapserver
I'm not much of a programmer, but I can stumble through most builds. What I'm
really looking for is a single place (if I have to write it myself) where I
can find the configuration arguments to use, what to avoid, etc. For
example, looking through all the archives and WiKi notes has just confused me
further concerning DSO's, CGI, etc. What is the best way to build Apache for
the purposes above? Do I need to build gd into every "support" library, or
just one? These are the types of questions that tend to haunt me. I would
like to have mysql as well, but it is becoming more apparent I should
concentrate on building a extremely lean (in apps) server designed to build
and serve maps.
Any thoughts? Any suggestions? I'm willing to read some more...and take
notes.
Respectfully,
Gerald Buckmaster
