[Mapserver-users] php regex error
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sun May 18 00:40:59 EDT 2003
Glad you got it working. However, I could have SWORN I checked your
configure options for php for system-regex.
Still, I think you're gonna be happier with the later PHP candidate.
gerry
Gerald Buckmaster wrote:
> Paul and Gerry,
> The combination of using newer source trees and configuring php
> --with-regex=system worked with Mandrake 9.1.
> Thanks for your help!
> Gerald
> On Saturday 17 May 2003 07:50 pm, Paul Spencer wrote:
>>try configuring php with --with-regex=system.
>>Cheers,
>>Paul
> OK,
> Thanks for the clue...might be worth pursuing.
> I've downloaded the latest php 4.3.2rcX and compiled fine, but MS 3.6.5 still
> gives me the same error...where do I download MS 3.7? Is it CVS only?
> Gerald
> On Saturday 17 May 2003 06:19 pm, Gerry Creager N5JXS wrote:
>>Gerald,
>>I hate writing negative-reporting responses, but I'm not going to be
>>able to help: RH 9/php 4.3.2RC1, Mapserver 3.7 and it just worked
>>flawlessly for me.
>>So I'm at a loss.
>>Have you tried capturing the config output to a file? Looked at
>>config.log? What did it say?
>>>All Concerned,
>>>I have seen this same problem exposed in the archives, but haven't seen a
>>>solution. First my system:
>>>Mandrake 9.1
>>>php 4.3.1 (source)
>>>mapserver 3.6.5 (source)
>>>My php configure:
>>>./configure --with-system-regex --with-mysql=/usr/local
>>>My mapserver 3.6.5 configure:
>>>./configure --with-jpeg=/usr/local \
>>>--with-png=/usr/local \
>>>--with-proj=/usr/local \
>>>--disable-ignore-missing-data \
>>>--with-php=/usr/local/src/php-4.3.1 \
>>>--with-gdal \
>>>--with-ogr \
>>>--with-postgis=yes \
>>>--disable-rxposix-conflict-error
>>>I get the error during the mapserver 3.6.5 configure process:
>>>checking whether we have PHP3 or PHP4... -DPHP4
>>>checking whether we should use PHP's regex... yes
>>>configure: error:
>>>!!! The current version of PHP MapScript has some problems with !!!
>>>!!! PHP4's bundled regex. Until we figure the solution to the !!!
>>>!!! problem, the workaround is to compile PHP4 with the system regex !!!
>>>!!! Please re-configure and re-compile PHP4 with --with-system-regex !!!
>>>!!! and then re-configure and re-compile MapServer. !!!
>>>How do I stop mapserver build from using the PHP regex? I am using the
>>>system regex during the building of PHP, so why am I still getting this
>>>configure error?
>>>Respectfully,
>>>Gerald Buckmaster
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
