[Mapserver-users] Shapefiles and queries
Adam Zornes
zornes at athenic.com
Mon May 19 13:29:54 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C31E2C.42D0A470
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
All,
=20
I am working on a project and am fiddling around with the
queries. I realize that I know nothing about how mapserver processes
queries. =20
What I would like to know is how points are used in queries.
Say you have a point and a layer. Does mapserver take said point and
look at each feature in the layer, calculating whether that point in
within each polygon and/or within a certain radius of the polygon? Or
does is there merely a center point for each polygon, and proximity to
this point is used by mapserver? =20
Can anyone enlighten me on this matter, or direct me to a
source which will?
=20
Cheers,
Adam Zornes
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C31E0A.CB722EB0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>All,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-tab-count:1'>  =
; </span>I
am working on a project and am fiddling around with the queries.<span
style=3D'mso-spacerun:yes'> </span>I realize that I know nothing =
about how <span
class=3DSpellE>mapserver</span> processes queries. <span
style=3D'mso-spacerun:yes'> </span><o:p></o:p></span></font></p>
; </span>What
I would like to know is how points are used in queries. Say you have a =
point
and a layer.<span style=3D'mso-spacerun:yes'> </span>Does <span
class=3DSpellE>mapserver</span> take said point and look at each feature =
in the
layer, calculating whether that point in within each polygon and/or =
within a
certain radius of the polygon? <span =
style=3D'mso-spacerun:yes'> </span>Or
does is there merely a center point for each polygon, and proximity to =
this
point is used by <span class=3DSpellE>mapserver</span>?<span
; </span>Can
anyone enlighten me on this matter, or direct me to a source which =
will?<o:p></o:p></span></font></p>
font-family:Arial'>Cheers,<o:p></o:p></span></font></p>
font-family:Arial'>Adam Zornes<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C31E2C.42D0A470--
