[Mapserver-users] Shapefiles and queries
Steve Lime
steve.lime at dnr.state.mn.us
Tue May 20 21:15:38 PDT 2003
Hi Adam: MapServer takes a point an tests it against features within a
given layer. The logic is this (for a point selecting polygon query):
- based on layer TOLERANCE values construct a spatial filter
(rectangle) to select candidate features with
Then for each feature:
- see if the point is in the polygon, if in STOP
- if not, compute the distance from the point to the polygon
- if the distance is less that TOLERANCE, STOP
There are variations on this depending on feature types or if multiple
results are allowed. I the guess the point is that MapServer is not
using some type of approximation to do queries.
Steve
>>> "Adam Zornes" <zornes at athenic.com> 05/19/03 12:29 PM >>>
All,
I am working on a project and am fiddling around with the
queries. I realize that I know nothing about how mapserver processes
queries.
What I would like to know is how points are used in queries.
Say you have a point and a layer. Does mapserver take said point and
look at each feature in the layer, calculating whether that point in
within each polygon and/or within a certain radius of the polygon? Or
does is there merely a center point for each polygon, and proximity to
this point is used by mapserver?
Can anyone enlighten me on this matter, or direct me to a
source which will?
Cheers,
Adam Zornes
More information about the MapServer-users
