[Mapserver-users] RE: [Mapserver-users] additional parameters for WMSÂ layer
John.Hockaday at ga.gov.au
Mon May 19 20:37:07 EDT 2003
Mike,
I feel what you are asking is an implementation problem and not a mapserv development issue. I wouldn't like to see mapserv develop some WMS parameters that are not OGC compliant. Not everyone allows cookies on their browser for security reasons and tying mapserv into a particular type of implementation would be dangerous unless it was compliant to the OGC specification.
I think that you could use hidden input types to pass the extra parameters backwards and forwards to your CGI scripts. However, I would be very surprised if the OGC specifications have not already catered for these extra parameters.
Just my initial thoughts on the idea.
John
> -----Original Message-----
> From: Mike V. Andreev [mailto:andreev at d902.iki.rssi.ru]
> Sent: Saturday, 17 May 2003 3:35
> To: mapserver-dev at lists.gis.umn.edu
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] additional parameters for WMSÂ layer
> Hello
> I have mapserever compiled with WMS client support and I use map file
> with defined WMS layer. This layer is a http reference to my
> perl script
> on the same http server. This script understand OGC WMS parameters in
> query string and can create maps whith information from some database.
> But to create sensible map this script need additional information in
> request. I wanted to use http cookies to store that parameters. But I
> have a problem here. Then my client send request to http server with
> mapserver URI request contain proper cookies but after that mapserver
> need to make http request to perl script URI and of couse this request
> contains no cookies.
> So I want to ask two question here:
> 1) Can somebody give me any hits to solve my problem with
> existing soft?
> 2) I have an idea how to extend mapserver functionality so it
> be able to
> solve my problem. So I want to ask what do you people think about it.
> There is my proposal: each layer object could contain boolean
> parameter
> http_cookies_forwad (disabled by default). So if this featcher enabled
> in layer with connectiontype equal to 'WMS' (and may be
> 'WFS') than when
> mapserver make http request to proper URL it sends additional http
> headers: 1) Cookie - header with cookies client send to
> mapserver and 2)
> X-Forwarder-For - header with original client ip (as far as mapserver
> can determine it).
> Just to illustrate my idea I've made simple patch to maphttp.c. I used
> today's (2003-05-16) nightly build. This patch contains only
> functionality for sending proper http request. There is no
> any stuff to
> support new feature in layreObj but I think whole idea is clear.
> 81a82,83
> > #define HTTP_COOKIES_FORWARDING 1
> 243a246,247
> > char *tmp_env_read, *strBuf = NULL;
> > struct curl_slist *slist=NULL;
> 366a371,392
> > /* If we need to forward http cookies to server */
> > if( HTTP_COOKIES_FORWARDING && (tmp_env_read =
> curl_getenv( "HTTP_COOKIE" ) ) != NULL ){
> > /*add cookies to http_handle*/
> > curl_easy_setopt(http_handle, CURLOPT_COOKIE,
> tmp_env_read);
> > /*add X-Forwarded-For header with original client ip */
> > if( (tmp_env_read = curl_getenv(
> "HTTP_X_FORWARDED_FOR" )) == NULL )
> "HTTP_FORWARDED" ) ) == NULL )
> "HTTP_CLIENT_IP" ) ) == NULL )
> > tmp_env_read = curl_getenv( "REMOTE_ADDR" );
> > if( tmp_env_read != NULL ){
> > #define HTTP_HEADER_BUF_LENGTH 100
> > strBuf = (char*)malloc( HTTP_HEADER_BUF_LENGTH );
> > snprintf( strBuf, HTTP_HEADER_BUF_LENGTH,
> "X-Forwarded-For: %s", tmp_env_read);
> > #undef HTTP_HEADER_BUF_LENGTH
> > slist = curl_slist_append( slist, strBuf);
> CURLOPT_HTTPHEADER, slist);
> 554a581,583
> > if( slist != NULL ){ curl_slist_free_all(slist); }
> > if( strBuf != NULL ){ free( strBuf ); }
> 556a586,587
> > #undef HTTP_COOKIES_FORWARDING
> ____________________________________________________________
> | Mike Andreev, software engineer andreev at d902.iki.rssi.ru |
> | SMIS Lab, Space Research Institute http://smis.iki.rssi.ru |
> |____________________________________________________________|
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
