[Mapserver-users] additional parameters for WMSÂ layer
Mike V. Andreev
andreev at d902.iki.rssi.ru
Tue May 20 09:36:08 EDT 2003
Hello John,
thanks for your comments.
> Mike,
> I feel what you are asking is an implementation problem and not a mapserv development issue. I wouldn't like to see mapserv develop some WMS parameters that are not OGC compliant. Not everyone allows cookies on their browser for security reasons and tying mapserv into a particular type of implementation would be dangerous unless it was compliant to the OGC specification.
> I think that you could use hidden input types to pass the extra parameters backwards and forwards to your CGI scripts. However, I would be very surprised if the OGC specifications have not already catered for these extra parameters.
I'm not sure what do you mean here. If you mean that OGC specification
already include my parameters then you are wrong. This is not geographic
parameters. For example it is a list of monitoring object or a datetime
range. But OGC WMS specification allows me to use additional parameters
in request to my CGI script, and if I would request my script directly
there isn't a problem.
But request to my script must be formed by mapserver. And it contains:
1) string from layerObj.connection and 2) parameters formed by mapserver
(such as BBOX, SRS, etc). I can not define additional parameters in
mapserver's map file because they must be chosen by and user and change
from query to query.
By the other hand I can send additional parameters from form fields
(hidden or not) only to mapserver and they will have no an effect on
request mapserver send to my script. Or may be I miss something in docs
and there is some special mapserver option for it ? This would be a
solution.
> Just my initial thoughts on the idea.
> John
> > -----Original Message-----
> > From: Mike V. Andreev [mailto:andreev at d902.iki.rssi.ru]
> > Sent: Saturday, 17 May 2003 3:35
> > To: mapserver-dev at lists.gis.umn.edu
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] additional parameters for WMSÂ layer
> > Hello
> > I have mapserever compiled with WMS client support and I use map file
> > with defined WMS layer. This layer is a http reference to my
> > perl script
> > on the same http server. This script understand OGC WMS parameters in
> > query string and can create maps whith information from some database.
> > But to create sensible map this script need additional information in
> > request. I wanted to use http cookies to store that parameters. But I
> > have a problem here. Then my client send request to http server with
> > mapserver URI request contain proper cookies but after that mapserver
> > need to make http request to perl script URI and of couse this request
> > contains no cookies.
> > So I want to ask two question here:
> > 1) Can somebody give me any hits to solve my problem with
> > existing soft?
> > 2) I have an idea how to extend mapserver functionality so it
> > be able to
> > solve my problem. So I want to ask what do you people think about it.
> > There is my proposal: each layer object could contain boolean
> > parameter
> > http_cookies_forwad (disabled by default). So if this featcher enabled
> > in layer with connectiontype equal to 'WMS' (and may be
> > 'WFS') than when
> > mapserver make http request to proper URL it sends additional http
> > headers: 1) Cookie - header with cookies client send to
> > mapserver and 2)
> > X-Forwarder-For - header with original client ip (as far as mapserver
> > can determine it).
> > Just to illustrate my idea I've made simple patch to maphttp.c. I used
> > today's (2003-05-16) nightly build. This patch contains only
> > functionality for sending proper http request. There is no
> > any stuff to
> > support new feature in layreObj but I think whole idea is clear.
> > 81a82,83
> > > #define HTTP_COOKIES_FORWARDING 1
> > 243a246,247
> > > char *tmp_env_read, *strBuf = NULL;
> > > struct curl_slist *slist=NULL;
> > 366a371,392
> > > /* If we need to forward http cookies to server */
> > > if( HTTP_COOKIES_FORWARDING && (tmp_env_read =
> > curl_getenv( "HTTP_COOKIE" ) ) != NULL ){
> > > /*add cookies to http_handle*/
> > > curl_easy_setopt(http_handle, CURLOPT_COOKIE,
> > tmp_env_read);
> > > /*add X-Forwarded-For header with original client ip */
> > > if( (tmp_env_read = curl_getenv(
> > "HTTP_X_FORWARDED_FOR" )) == NULL )
> > "HTTP_FORWARDED" ) ) == NULL )
> > "HTTP_CLIENT_IP" ) ) == NULL )
> > > tmp_env_read = curl_getenv( "REMOTE_ADDR" );
> > > if( tmp_env_read != NULL ){
> > > #define HTTP_HEADER_BUF_LENGTH 100
> > > strBuf = (char*)malloc( HTTP_HEADER_BUF_LENGTH );
> > > snprintf( strBuf, HTTP_HEADER_BUF_LENGTH,
> > "X-Forwarded-For: %s", tmp_env_read);
> > > #undef HTTP_HEADER_BUF_LENGTH
> > > slist = curl_slist_append( slist, strBuf);
> > CURLOPT_HTTPHEADER, slist);
> > 554a581,583
> > > if( slist != NULL ){ curl_slist_free_all(slist); }
> > > if( strBuf != NULL ){ free( strBuf ); }
> > 556a586,587
> > > #undef HTTP_COOKIES_FORWARDING
> > ____________________________________________________________
> > | Mike Andreev, software engineer andreev at d902.iki.rssi.ru |
> > | SMIS Lab, Space Research Institute http://smis.iki.rssi.ru |
> > |____________________________________________________________|
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
