[Mapserver-users] Building gdal with Xerces
Benjamin Thelen CCGIS
benjamin.thelen at ccgis.de
Tue May 20 13:04:59 EDT 2003
Hi Frank,
Thanks for your help!
I twice removed gdal-1.1.8, installed xerces 1.7.0 and installed gdal again,
just to be sure. But gdal does not recognize xerces 1.7.0. While compiling
you can see a few "c++ -c -DHAVE_XERCES=0 ...". I suppose that means that
Xerces was either not recognized or not requested by gdal.
This is the Makefile from the FreeBSD-Ports-Collectoin for gdal-1.1.8:
# New ports collection makefile for: Geospatial Data Abstraction Library
# Date created: 27 Aug 2001
# Whom: Randall Hopper
# $FreeBSD: ports/graphics/gdal/Makefile,v 1.7 2003/02/20 18:08:00 knu Exp $
PORTNAME= gdal
PORTVERSION= 1.1.8
CATEGORIES= graphics
MASTER_SITES= ftp://ftp.remotesensing.org/pub/gdal/
MAINTAINER= ports at FreeBSD.org
COMMENT= A translator library for raster geospatial data formats
BUILD_DEPENDS= ${LOCALBASE}/bin/doxygen:${PORTSDIR}/devel/doxygen
LIB_DEPENDS= jpeg.9:${PORTSDIR}/graphics/jpeg \
png.5:${PORTSDIR}/graphics/png \
tiff.4:${PORTSDIR}/graphics/tiff
USE_PYTHON= yes
USE_GMAKE= yes
GNU_CONFIGURE= yes
CONFIGURE_ARGS= --with-libz=internal \
--with-png=internal \
--with-libtiff=internal \
--with-libgeotiff=internal \
--with-libjpeg=internal \
--with-libgif=internal \
--with-python
MAKEFILE= GNUmakefile
INSTALLS_SHLIB= yes
.include <bsd.port.mk>
I suppose that this looks a little different to the one from the source code
made by ./configure?!
But, obviously there is no --with-xerces. Shouldn't that be there?
I then added --with-xerces to CONFIGURE_ARGS and had the following compiling
error:
checking for Xerces C++... requested, but compile or link fails!
c++ -I/usr/local/include/xercesc -I/usr/local/include -o conftest
conftest.cpp -lxerces-c1_6_0 -lpthread -lm -L/usr/local/lib
/usr/libexec/elf/ld: cannot find -lxerces-c1_6_0
configure: error: Please correct Xerces options, or don't enable Xerces.
===> Script "configure" failed unexpectedly.
Please report the problem to ports at FreeBSD.org [maintainer] and attach
the "/usr/ports/graphics/gdal/work/gdal-1.1.8/config.log" including
the
output of the failure of your make command. Also, it might be a good
idea to provide an overview of all packages installed on your system
(e.g. an `ls /var/db/pkg`).
*** Error code 1
Stop in /usr/ports/graphics/gdal.
root at qwertzuiop#
As I have installed xerces-1.7.0, I suppose "/usr/libexec/elf/ld: cannot
find -lxerces-c1_6_0" is quite obvious?!
Well, I am not familiar with bugzilla. Do you want me to file exactly this
to bugzilla?
I'll also try to get xerces-1.6.0, as I don't think I urgently need 1.7.0.
But I am not sure whether I'll be successful (Ports-Collection-Problem
again). Another problem will be, that it will surely take some time until
your changes will be maintained to the FreeBSD-Ports-Collection. I would
have to install via sourc-code directly.
What do you think?
Regards,
Benjamin
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Frank
> Warmerdam
> Sent: Friday, May 16, 2003 7:50 PM
> To: Benjamin Thelen (CCGIS)
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Building gdal with Xerces
> Benjamin Thelen (CCGIS) wrote:
> > That means 1.7.0 won't run? Do you think, that xerces 1.6.0 would
> > automatically be recognized by gdal at installation time of
> gdal? Otherwise
> > I would have to find out what to specify for --with-xerces-in=dir
> > and --with-xerces-lib=opts. Especiall the last one is a miracle to me.
> > Thanks,
> > Ben
> Ben,
> Xerces should be found automatically if it is in the default locations
> (I think). The --with-xerces-lib and --with-xcerces-inc items can be
> used to specifically control the include and link directives if necessary.
> Generally if you build and install xerces in a non-standard location you
> can use --with-xerces=/opt or something similar.
> 1.7.0 likely will work, and I thought that some 2.x versions were working
> after I made a slight improvement to the include logic, but I am a bit
> uncertain about this. I am willing to update the GML code to support more
> modern Xerces versions if you need. Just file a bug report in Bugzilla.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
