[Mapserver-users] known issue: no results with QueryByPoint (Mapserver 3.7 PHP mapscript)
Vincent Schut
schut at sarvision.com
Wed May 21 08:17:43 EDT 2003
You need to set STATUS ON for your layer to be queriable.
Cheers,
Vincent.
On Wednesday 21 May 2003 13:41, Michael Härtel wrote:
> Hello All!
> There are many references to articles about the problem that no results
> are returned by QueryByPoint.
> i' ve read all of them but i still can't figure out why i get no results.
> This is what i have:
> 1.) A Query Layer ($querylayer) with a template file:
> object(layer)(35) { ["_handle_"]=> resource(50) of type (layerObj)
> ["_map_handle_"]=> resource(1) of type (mapObj) ["numclasses"]=>
> int(0) ["index"]=> int(7) ["status"]=> int(0) ["classitem"]=>
> string(0) "" ["name"]=> string(11) "WRS-2_frame" ["group"]=> string(0)
> "" ["data"]=> string(9) "wrs2/wrs2" ["type"]=> int(2) ["tolerance"]=>
> float(3) ["toleranceunits"]=> int(6) ["symbolscale"]=> float(-1)
> ["minscale"]=> float(-1) ["maxscale"]=> float(-1) ["labelminscale"]=>
> float(-1) ["labelmaxscale"]=> float(-1) ["maxfeatures"]=> int(-1)
> ["transform"]=> int(1) ["labelcache"]=> int(1) ["postlabelcache"]=>
> int(0) ["labelitem"]=> string(0) "" ["labelsizeitem"]=> string(0) ""
> ["labelangleitem"]=> string(0) "" ["tileitem"]=> string(8) "location"
> ["tileindex"]=> string(0) "" ["header"]=> string(32)
> "H:\_webroot_\mapserv_header.html" ["footer"]=> string(32)
> "H:\_webroot_\mapserv_footer.html" ["connection"]=> string(0) ""
> ["connectiontype"]=> int(1) ["filteritem"]=> string(0) ""
> ["template"]=> string(40) "H:\_webroot_\mapserv_query_template.html"
> ["transparency"]=> int(0) ["styleitem"]=> string(0) "" ["offsite"]=>
> object(color)(4) { ["_handle_"]=> resource(51) of type (Unknown)
> ["red"]=> int(-1) ["green"]=> int(-1) ["blue"]=> int(-1) } }
> 2.) A Point Object with geographic coordinates:
> object(point)(4) { ["_handle_"]=> resource(52) of type (Unknown)
> ["x"]=> float(9.85) ["y"]=> float(50.9) ["m"]=> float(50.9) }
> 3.) A call to Query function (with tolerance set in map file):
> $query=$querylayer->QueryByPoint($my_point,MS_MULTIPLE,-1);
> 4. The entry of the query-layer in the map file:
> LAYER #wrs2
> NAME "WRS-2_frame"
> PROJECTION
> proj=longlat
> ellps=WGS84
> datum=WGS84
> no_defs
> END
> DATA "wrs2/wrs2"
> STATUS OFF
> TYPE POLYGON
> TOLERANCEUNITS kilometers
> TOLERANCE 5
> DUMP TRUE
> HEADER "H:\_webroot_\mapserv_header.html"
> TEMPLATE "H:\_webroot_\mapserv_query_template.html"
> FOOTER "H:\_webroot_\mapserv_footer.html"
> END # layer wrs2
> 4.) The map i use is a world map with these parameters:
> EXTENT -180.000000 -90.000000 180.000000 90.000000
> SIZE 600 300
> UNITS DD
> PROJECTION
> proj=longlat
> ellps=WGS84
> datum=WGS84
> no_defs
> END
> What i get is the common error message:
> "Warning: MapServer Error in msQueryByPoint(): No matching record(s) found"
> The query layer extends over the whole map.
> These actions were already performed without any change to the result:
> 1. changed tolerance to 1 in QueryByPoint function call
> 2. MS_SINGLE mode tried instead of MS_MULTIPLE
> 3. Pixel coordinates in Point object used instead of geographic coordinates
> So what the **** am i doing wrong? Unfortunately i can´t find an example
> of a template file where i could look how the results can be printed.
> But i guess i need a result first and THEN there may occur errors
> concerning a misconfiguration because of a missing/wrong template file.
> Do i actually need a template file if i use mapserver 3.7 with
> mapscript? Or is it only needed by the simple CGI version?
> Thanks for any reply, i'm glad to know that there are some real freaks
> out there :)
> (im looking forward to a documentation about how to perform queries with
> mapserver 3.7 and mapscript).
> Michael Härtel
> Georg-August University Goettingen
> Department of Geography
> Cartography, GIS & Remote Sensing Section
> project Notebook University, Internet Map Service
> Goldschmidtstr. 5 Tel.: +49 (0)551/39-12671
> 37077 Goettingen Fax : +49 (0)551/39-8020
> http://www.geogr.uni-goettingen.de/kuf/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
