[Mapserver-users] known issue: no results with QueryByPoint (Mapserver 3.7 PHP mapscript)
Vincent Schut
schut at sarvision.com
Wed May 21 08:46:13 EDT 2003
On Wednesday 21 May 2003 10:37, Eric Bridger wrote:
> On Wed, 2003-05-21 at 11:41, Michael Härtel wrote:
> > Do i actually need a template file if i use mapserver 3.7 with
> > mapscript? Or is it only needed by the simple CGI version?
> You don't need the "actual" template file, but you do need the TEMPLATE
> attribute set in the layer. E.g. TEMPLATE "dont_exist.html". I'm not
> sure if this is still true in 3.7
Yes, this is still the case in 3.7.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
